how to determine host ip that is connected to switch?
Jun 16th, 2010
I have a Cisco 4000 CatOS switch.  I ran "show cam dynamic" and  it listed the MAC of the servers connected to the switch. Is there a command that will show the ip address or a way that i can use the mac address to determine the respective ip address?
thanks,
ricardo
Ganesh Hariharan Wed, 06/16/2010 - 21:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
thanks,
ricardo
Hi Ricardo,
Show arp is the command which will tell you the assoiciated ip with mac in interface .
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
glen.grant Thu, 06/17/2010 - 05:22
  If you have multiple vlans on the switch the show arp won't help.  You would have to compare the cam listing on the catos device to the layer 3 routing device arp table to resolve them .  If its a single vlan on the switch and the management address is in the same address space then you can look at the arp table .  A cat 4000 is a layer 2 only device so the arp table can only be used if the management interface (SC0) is in the same address space.
