mls rate-limit all ttl-failure
Jun 16th, 2010
   Could some one  let  me know the  real usuage of the below given command and how it works for a 6500 chasis
mls rate-limit all ttl-failure 2500 10
Cheers
Ajai
Ganesh Hariharan Wed, 06/16/2010 - 22:06
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Cheers
Ajai
Hi Ajai,
Supervisor 720 module have hardware that can be used to limit how often the CPU will be interrupted by packets with expiring TTL. This example shows how to enable the hardware rate limiter and check its operation:
Router#mls rate-limit all ttl-failure 500 100
Router#show mls rate-limit
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
athambi Wed, 06/16/2010 - 22:13
but will this command be of any use  if there are packets that are hitting the  6500 with a ttl of  1 .I am  trying to  block the packets that  hit the  6500 with a ttl of 1 ..
Ajai
