Guest Wireless Web Authenticaion using SSL (WLC)
Jun 16th, 2010
We have a Cisco WLC (version 4.2.61.0) which we use for our corporate and guest wireless.
For guests, after they associate and open a web browser they are directed to a login page asking them for their user credentials.  Currently this login page is a customized page on the WLC it self and only uses HTTP.
Is it possible to have the WLC using HTTPS for this page?
Or do i need to redirect the login page to an external server?
thanks,
Overall Rating: 5 (1 ratings)
dancampb Thu, 06/17/2010 - 06:14
  • Cisco Employee,
If you have HTTPS enabled on the controller the webauth login page should use SSL.  Just go under Management - HTTP and make sure you have HTTPS enabled.  If you don't have it enable the webauth page would not be encrypted.
LucaSalvatore_2 Thu, 06/17/2010 - 14:42
Yes that worked! thanks!
Is it possible to install a valid certificate so the certificate error page is not displayed when someone uses the webauth?
How is this done if it is possible?
jhedstr2 Fri, 06/18/2010 - 00:49
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
That no problem. Just follow the guide in one of these documents:
Chained certificate (think you need to upgrade your system to use chained certifcate) :
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a77592.shtml
Unchained certificate:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
Hope it helps.
Kind regards
Johan
Trending Topics - Security & Network
