1142N Regulatory Domain
Answered Question
Jun 17th, 2010
Can someone please confirm which model 1142N APs I need to buy to operate in Australia with 4404 WLCs please? From what I can tell I need model AIR-LAP1142N-N-K9, is this correct? We're still running pre-CAPWAP v4.2.x.x software on the WLCs by the way.
Thank you.
Brodie
Correct Answer by Leo Laohoo about 6 years 9 months ago
Australia should be using the "N" regulatory domain.  And Rob's right, 1140 is supported on the 6.X (and later) firmware.
Overall Rating: 4.5 (2 ratings)
Correct Answer
Rob Huffman Thu, 06/17/2010 - 05:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
brodierad Thu, 06/17/2010 - 21:46
Thanks for the good news. When they didn't associate it crossed my mind that I may have bought over a hundred of these with the incorrect reg domain. But now I'm pretty sure I just have to upgrade the WLC software. I'll go to the v6.x assurewave software I guess.
Rob Huffman Fri, 06/18/2010 - 05:43
  • Hall of Fame,
    Founding Member
Hi Brodie,
Good stuff
Yes, I'm sorry I missed that in your first post, but the 1140 series was not supported
in any 4.x.x.x WLC versions. I like your thinking of upgrading to the Assurewave
6.x. Make sure we check the exact upgrade path to 6.x before moving forward.
Cheers!
Rob
brodierad Sun, 06/20/2010 - 18:28
Yep, I'm going:
WLCs 4.2.207.0 to 6.0.196.0
WCS 4.2.128.0 to 6.0.181.0
Location App 3.1.43.0 to 6.0.101.0
Cisco Secure ACS 4.1 to 4.2
That should do it.
Cheers
Leo Laohoo Sun, 06/20/2010 - 18:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Thanks for the ratings.
By the way, firmware 7.X is now available.
brodierad Sun, 06/20/2010 - 20:54
It'd take some convincing to upgrade to a new version without a ribbon.
Correct Answer
Leo Laohoo Fri, 06/18/2010 - 16:26
  • Hall of Fame,
    2017 LAN, Wireless
