SNMP on DMS 5.2
Answered Question
Jun 17th, 2010
Hi all,
Has anyone implemented/enabled the SNMP module on DMS?
Correct Answer by Tomas De Leon about 6 years 9 months ago
"The only issue i'm facing now, is that while i'm receiving syslong,snmp for the DMPS unreachable, i cant receive the email notification.
Is anything wrong with the email notifications on 5.2?"
Please explain further...
The only Alerts for DMPs are DMP Outages, Restarts, IP Conflicts, and Registrations.   Define what you
mean by unreachable?
The Email, Syslog, & SNMP all appear to be working in my 5.2 setup for the alerts listed above.
T.
Overall Rating: 4.4 (6 ratings)
Tomas De Leon Thu, 06/17/2010 - 05:20
  • Cisco Employee,
Yes, I have the module configured & enabled.
Do you have specific question(s) on configuring?
T.
panayiotiscy Thu, 06/17/2010 - 23:37
Hi Tomas,
Thanks for asking because i do have some guestions(!) :
1) What NMS software are you using?
2) How much effort is needed(in terms of configuration) after "importing" the 2 .my files from Cisco to your NMS in order for the NMS to be able to receive the traps from DMS?
Tomas De Leon Fri, 06/18/2010 - 07:50
  • Cisco Employee,
I use Kiwi Syslog Tools for my testing.
http://www.kiwisyslog.com/
Not much configuration to get this to work.
Just follow the DMM User Guide and the
Kiwi Readme docs.  Very little to config.
T.
panayiotiscy Tue, 06/22/2010 - 03:35
But this is only to receive the syslogs?
What about the snmp?
Tomas De Leon Tue, 06/22/2010 - 05:30
  • Cisco Employee,
I also use it for SNMP.  You can configure it for SNMP.  Download
the free trial and test it out.
Cheers!
T.
panayiotiscy Wed, 06/23/2010 - 01:10
HI Tomas,
I have downloaded the Syslog Server from Kiwi but i cant import the .my files from Cisco.
I can only receive the SNMP traps to the Kiwi but they are "translated" to syslog.
Am i doing something wrong here?
Tomas De Leon Wed, 06/23/2010 - 08:13
  • Cisco Employee,
The Kiwi Syslog application was suggested to use for monitoring DMS Syslog & SNMP alerts not for
a NMS application for all of your Cisco or other devices.  I am sure the Solarwinds and other
vendors have a full compliment of tools and services.
What I use for my DMS setup is the following:
* Kiwi Syslog for DMS SNMP & Syslog ALERT notifications
* iReasoning for DMS MIB Browsing
I am not a NMS Expert and would advice you to seek additional assistance if
you are looking for a "Complete" NMS Tool for ALL of your Network Entities..
Cheers
T.
panayiotiscy Wed, 06/23/2010 - 23:39
Hi Tomas,
Thank you for sharing with me(us) your DMS setup.
Indeed, ireasoning seems to be receiving the DMS traps at once without a lot of configuration in comparison with solarwinds and whatsup!
I'm also using the kiwi and i can receive the syslogs just fine.
Thank you
Correct Answer
Tomas De Leon Thu, 06/24/2010 - 05:31
  • Cisco Employee,
T.
panayiotiscy Thu, 06/24/2010 - 23:55
Under Outages you can select the DMPs are unreachable and get notified by Email,SNMP,SYSLOG
and under Restarts/Registrations you can select  DMPs have restarted and once again you can get notified by Email,SNMP and SYSLOG.
In order to thest the above, i'm restarting the DMP and i can only receive SNMP and SYSLOG.
But, apparently i had mis-configured the SMTP ip address  and as a result i couldnt receive any email notifications.
Now everything is ok!
Thank you Tomas
Related Content
