Cisco 2811 ISR to 2911 ISR
Jun 17th, 2010
Cisco 2811 supports NM-1A-T3/E3 module. But since this model is nearing EOL. I am planning to replace it with the Cisco 2911 ISR router.
The question is - will the Cisco 2911 ISR support ATM technology ?
It would be supporting a 10 mbps link. What is the equivalent model in the Cisco 2900 family should you recommend?
Thanks and regards,
Gill
