LMS 3.1/ Multiple community strings on Discovery
Answered Question
Jun 17th, 2010
Is the multiple community strings has been set up under the Discovery settings , does it slow down the Discovery itself ?
Richard
Correct Answer by Joel Monge about 7 years 1 week ago
If the communities fail, the discovery will be slower.  If the first community you have matches, then next ones are not tried.  If no community matches, it will go through all your communities list and all their timeouts-retries.
The SNMP timeouts are incremental.  That is, if you have a 4 second timeout with 2 retries, the first try it will wait 4 seconds, second try it will wait 8 seconds and third try it will wait 16 seconds.
Refer to the following DOC for a detailed explanation of the discovery in LMS.
Overall Rating: 5 (1 ratings)
Correct Answer
Joel Monge Thu, 06/17/2010 - 08:16
  • Cisco Employee,
richard.tetu Tue, 06/22/2010 - 01:07
Hello Joel,
That' s what I thought but i need confirmation from the processus itself .
My end users are using , wild card and complete adresses. Both are used but for the all network.
There are more than 40 community strings entered.
Richard.
