ACS versus ACS Express :- Feature *Matrix* Available ?
Jun 17th, 2010
I want to compare ACS 5.x versus ACS Express 5.x.
I cannot find a SIMPLE 1 page feature MATRIX. Does anyone know if such a document is available ?
     Apart for number of devices supported etc, are there any key features missing is Express ?
           I know that they are different platforms etc.. so I expect differences.
           But from what I have briefly looked at they bot seem to support the same feature set.
            I am not sure how much the reporting and monitoring features differ though.
Thanks.
Waris Hussain Mon, 06/28/2010 - 17:01
Unfortunatley there is no specific document on the comparison but however there are more features in ACS5.0 as comparison to ACS exp.
the report and monitoring  of ACS5.0 is more informative then ACS exp.
Here is a doc for ACS5.0  logging :
http://cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.0/user/guide/monit_report.html
here is the doc for ACS exp logging :
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_express/5.0/user/guide/reports.html
In the meantime if i find any comaprison doc i will relay that to you.
Waris Hussain.
