MVPN logging message in aggrigatoin router
Jun 17th, 2010
Hallo Folks,
We are reciving logggin message from last one month in our secondary aggrigation router from one of the PE router.
The CCTV traffic is running on MVPN.
The message is as follows
47677: Jun 17 12:25:06.451 GMT: %PIM-6-INVALID_RP_JOIN: Received (*, 239.160.11.34) Join from 172.16.2.22 for invalid RP 10.160.255.3
Our P network is running on SSM and PE is enable with Auto-RP features,We have around 20 PE which is working fine,only from this PE where the range
239.160.11.34 camera connected PE is the probelm.
These range camere are working fine,no porbelm with streaming,but we are getting logging message in AGG router.
There is not filtering is going on all are fine,please see the below RP mapping from these PE where probelm coming.
PE1#sh ip pim vrf cctv rp mapping
PIM Group-to-RP Mappings
Group(s) 224.0.0.0/4
  RP 10.160.255.3 (?), v2v1
    Info source: 10.160.255.3 (?), elected via Auto-RP
         Uptime: 3d01h, expires: 00:02:39
PE1#sh ip pim vrf cctv rp mapping elected
         Uptime: 3d01h, expires: 00:02:2
Please suggest me something,we are getting these message in our Monitoring tool also.
Ganesh Hariharan Wed, 06/23/2010 - 23:39
Hallo Folks,
Check out the below link fo troubleshooting the problem for above mentioned error in multicast,Hope to Help !!
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080094b55.shtml
Ganesh.H
Remember to rate the helpful post
sajism220 Thu, 06/24/2010 - 01:08
I Checked the same with this documents,still no luck..
I am still reciving the logs
Giuseppe Larosa Thu, 06/24/2010 - 06:22
Hello Sajiism220,
actually everything looks like fine about this customer RP
the error message decoder provides the following feedback
1. %PIM-6-INVALID_RP_JOIN: Received (*, [IP_address]) Join from [IP_address] for invalid RP  [IP_address]
A downstream PIM router sent a join message for the shared tree,  which this router does  not want to accept. This behavior indicates that this router will let  only downstream routers join to  a specific rendezvous point.
Recommended Action: Configure all downstream leaf routers to join to the RP that is  allowed by  upstream routers toward the validated rendezvous point.
Related documents- No specific documents apply to this  error message.
There is any difference on this PE node ?
different IOS image, different model/platform?
There is built redundancy, that is the VRF site is multihomed and there are two PE nodes serving the site?
what is the output of
sh ip vrf ?
where is the
how is configured the multicast VPN?
are all multicast addresses allowed to join?
what is the output of sh ip pim rp mapping ?
Hope to help
Giuseppe
sajism220 Thu, 06/24/2010 - 06:51
Hallo Giulsar,
Thanks for the update,here is the answers for the below questions.
I compared with other PE's,there is not diffrence in the configuration,the cctv CAMERA which is belongs to this PE alredy working fine,only we are getting logs.
We are using same IOS for all PE's,The IOS version is SRB6,and the hardware platform is 7609 chassis with SUP32
No two PE node serving this site,This PE has dual uplink to agg1 and agg2 router.The agg1 is primary and agg2 is secondary.
sh ip vrf ?
PE1#sh ip vrf cctv
  Name                             Default RD          Interfaces
  cctv                             16999:1000080041    Vl200
        Tu0
         Uptime: 1w3d, expires: 00:02:21
where is the
Customer RP is located in another PE which is located in our datacenter.
Mulitcast VPN is configured by enabling AUTORP in PE and SSM mode in P's ,and there tunnel 0 to RP from each PE.
Yes,I have allowed the same SSM access list in PE's and P as well
PE1#sh ip pim vrf cctv rp mapping 239.160.11.38
         Uptime: 1w3d, expires: 00:02:52
Giuseppe Larosa Sat, 07/03/2010 - 11:06
Hello Sajsm220,
have you had any feedback from Cisco TAC about these messages in MVPN scenario ?
Hope to help
Giuseppe
sajism220 Sat, 07/03/2010 - 22:12
I didn't raise the TAC,since this is service provider envoirment,there are lot of people are using IPTV service espesally WC2010
We thought of rasing the same after this WC2010,but do you have any feedback regarding this probelms.
-Saji
