Hunt Pilot using VG224 analog lines
Answered Question
Jun 17th, 2010
I'm trying to setup a hunt pilot using serveral analog lines from my vg224.  When I use these DN numbers assoicated with the VG
224 I get a busy signal.  if I use any other DN number, such as an IP phone the Hunt pilot works correctly.  Since it works correctly with
the IP Phone DN number, I'm guessing I have the hunt pilot configured correctly.  Is there any reason why it won't work with DN numbers assoicated with a VG224 device?  I'm using Call Manager 6.1.4.2000-5.  VG224 IOS is 12.4(24)T3
Mike C.
Correct Answer by rob.huffman about 6 years 7 months ago
Hi Mike,
The VG224 ports are "logged out" of Hunt Groups by default.
If you put a tick in the "Logged into Hunt Group" box at the Device Level on the VG224 that should fix it."
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Overall Rating: 5 (1 ratings)
