871 VPN outside conection problem
pwolsza_wolfik1
I have a 871 Cisco router which shoud be configured to allow laptops from outside connect to corporate network.
I used Easy VPN ServerWizard in CCP to create configuration.
After using test the VPN everything looks OK.
Unfortunatlly I can't login trough VPN using Microsoft VPN connection (error 800) or using VPN Cisco Client.
Error 412: the remote peer is no longer responding.
Any sugestions ??
Patryk,
If you want to connect using the windows VPN client you can set PPTP on the router and optional MPPE encryption.
Here's a good link:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a00801e51e2.shtml
Federico.
9 Replies 9
Hi Patryk,
Eazy VPN is to connect the IPsec client.
If you're connecting with windows native VPN client, then the VPN is PPTP or L2TP.
Could you post the output of the ''sh run'' from the router to review the configuration? (you can remove the sensitive information).
Federico.
Hmmm I was think that something is wrong.
Below running-connfig
Building configuration...
Current configuration : 13977 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname xxx
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
logging buffered 51200
logging console critical
enable secret 5 x
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-XXX
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-XXX
revocation-check none
rsakeypair TP-self-signed-XXX
crypto pki certificate chain TP-self-signed-XXX
certificate self-signed 01
XXXXX
      quit
dot11 syslog
no ip source-route
ip cef
no ip bootp server
ip domain name xxx.xxx
ip name-server 153.19.0.50
ip name-server 153.19.250.100
no ipv6 cef
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
username test privilege 15 secret 5 xxx
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-any CCP-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect gnutella match-any ccp-app-gnutella
match  file-transfer
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match  service any
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match  service any
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match  service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
class-map type inspect kazaa2 match-any ccp-app-kazaa2
match  file-transfer
class-map type inspect match-all ccp-protocol-p2p
match class-map ccp-cls-protocol-p2p
match  service text-chat
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect http match-any ccp-app-httpmethods
match  request method bcopy
match  request method bdelete
match  request method bmove
match  request method bpropfind
match  request method bproppatch
match  request method connect
match  request method copy
match  request method delete
match  request method edit
match  request method getattribute
match  request method getattributenames
match  request method getproperties
match  request method index
match  request method lock
match  request method mkcol
match  request method mkdir
match  request method move
match  request method notify
match  request method options
match  request method poll
match  request method propfind
match  request method proppatch
match  request method put
match  request method revadd
match  request method revlabel
match  request method revlog
match  request method revnum
match  request method save
match  request method search
match  request method setattribute
match  request method startrev
match  request method stoprev
match  request method subscribe
match  request method trace
match  request method unedit
match  request method unlock
match  request method unsubscribe
class-map type inspect edonkey match-any ccp-app-edonkey
match  file-transfer
match  text-chat
match  search-file-name
class-map type inspect http match-any ccp-http-blockparam
match  request port-misuse im
match  request port-misuse p2p
match  req-resp protocol-violation
class-map type inspect edonkey match-any ccp-app-edonkeydownload
match  file-transfer
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect edonkey match-any ccp-app-edonkeychat
match  text-chat
class-map type inspect http match-any ccp-http-allowparam
match  request port-misuse tunneling
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect fasttrack match-any ccp-app-fasttrack
match  file-transfer
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect p2p ccp-action-app-p2p
class type inspect edonkey ccp-app-edonkeychat
  log
  allow
class type inspect edonkey ccp-app-edonkeydownload
  log
  allow
class type inspect fasttrack ccp-app-fasttrack
  log
  allow
class type inspect gnutella ccp-app-gnutella
  log
  allow
class type inspect kazaa2 ccp-app-kazaa2
  log
  allow
policy-map type inspect im ccp-action-app-im
class type inspect aol ccp-app-aol
  log
  allow
class type inspect msnmsgr ccp-app-msn
  log
  allow
class type inspect ymsgr ccp-app-yahoo
  log
  allow
class type inspect aol ccp-app-aol-otherservices
  log
  reset
class type inspect msnmsgr ccp-app-msn-otherservices
  log
  reset
class type inspect ymsgr ccp-app-yahoo-otherservices
  log
  reset
policy-map type inspect http ccp-action-app-http
class type inspect http ccp-http-blockparam
  log
  reset
class type inspect http ccp-app-httpmethods
  log
  reset
class type inspect http ccp-http-allowparam
  log
  allow
policy-map type inspect imap ccp-action-imap
class type inspect imap ccp-app-imap
  log
policy-map type inspect pop3 ccp-action-pop3
class type inspect pop3 ccp-app-pop3
  log
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
  service-policy http ccp-action-app-http
class type inspect ccp-protocol-imap
  inspect
  service-policy imap ccp-action-imap
class type inspect ccp-protocol-pop3
  inspect
  service-policy pop3 ccp-action-pop3
class type inspect ccp-protocol-p2p
  inspect
  service-policy p2p ccp-action-app-p2p
  inspect
  service-policy im ccp-action-app-im
class type inspect ccp-insp-traffic
  inspect
class type inspect CCP-Voice-permit
  inspect
class class-default
  pass
class type inspect sdm-access
  inspect
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address 100.100.100.100 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.179.12 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 213.192.73.209
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip access-list extended SDM_HTTPS
remark CCP_ACL Category=1
permit tcp any any eq 443
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.179.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 100.100.100.100 0.0.0.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Patryk,
Are you trying to connect using the windows VPN client or the IPsec client from Cisco?
Federico.
Above configuration is just before the rules which should allow to create vpn conection for user with laptops.
I was trying to connect using windows vpn and Cisco Easy VPN Client.
No success.
For me is beter to use windows client.
Patryk,
Here's a good link:
Federico.
Many thanks for the help.
Above tutorial helped me a lot.
I have a some problme with standard ACL list n C871 but I hope I can handle it
Retturning to my problem I made a configuration unfortunattly
when I want to connect to router computer receiving VPN error 691.
This is log:
005742: *Jun 24 17:26:28.170 PCTime: VPDN Received L2TUN socket message
005743: *Jun 24 17:26:28.182 PCTime: VPDN uid:76 L2TUN socket session accept requested
005744: *Jun 24 17:26:28.182 PCTime: VPDN uid:76 Setting up dataplane for L2-L2, no idb
005745: *Jun 24 17:26:28.190 PCTime: VPDN Received L2TUN socket message
005746: *Jun 24 17:26:28.198 PCTime: VPDN uid:76 VPDN session up
005747: *Jun 24 17:26:28.210 PCTime: ppp76 PPP: Send Message[Dynamic Bind Response]
005748: *Jun 24 17:26:28.210 PCTime: ppp76 PPP: Using vpn set call direction
005749: *Jun 24 17:26:28.210 PCTime: ppp76 PPP: Treating connection as a callin
005750: *Jun 24 17:26:28.210 PCTime: ppp76 PPP: Session handle[BC00004E] Session id[76]
005751: *Jun 24 17:26:28.210 PCTime: ppp76 PPP: Phase is ESTABLISHING, Passive Open
005752: *Jun 24 17:26:28.210 PCTime: ppp76 LCP: State is Listen
005753: *Jun 24 17:26:30.202 PCTime: ppp76 LCP: I CONFREQ [Listen] id 1 len 21
005754: *Jun 24 17:26:30.202 PCTime: ppp76 LCP:    MRU 1400 (0x01040578)
005755: *Jun 24 17:26:30.202 PCTime: ppp76 LCP:    MagicNumber 0x4CDC3223 (0x05064CDC3223)
005756: *Jun 24 17:26:30.202 PCTime: ppp76 LCP:    PFC (0x0702)
005757: *Jun 24 17:26:30.202 PCTime: ppp76 LCP:    ACFC (0x0802)
005758: *Jun 24 17:26:30.202 PCTime: ppp76 LCP:    Callback 6  (0x0D0306)
005759: *Jun 24 17:26:30.202 PCTime: ppp76 PPP: Authorization NOT required
005760: *Jun 24 17:26:30.202 PCTime: ppp76 LCP: O CONFREQ [Listen] id 1 len 15
005761: *Jun 24 17:26:30.202 PCTime: ppp76 LCP:    AuthProto MS-CHAP (0x0305C22380)
005762: *Jun 24 17:26:30.202 PCTime: ppp76 LCP:    MagicNumber 0xA079A8CF (0x0506A079A8CF)
005763: *Jun 24 17:26:30.206 PCTime: ppp76 LCP: O CONFREJ [Listen] id 1 len 7
005764: *Jun 24 17:26:30.206 PCTime: ppp76 LCP:    Callback 6  (0x0D0306)
005765: *Jun 24 17:26:30.206 PCTime: ppp76 LCP: I CONFACK [REQsent] id 1 len 15
005766: *Jun 24 17:26:30.206 PCTime: ppp76 LCP:    AuthProto MS-CHAP (0x0305C22380)
005767: *Jun 24 17:26:30.206 PCTime: ppp76 LCP:    MagicNumber 0xA079A8CF (0x0506A079A8CF)
005768: *Jun 24 17:26:30.206 PCTime: ppp76 LCP: I CONFREQ [ACKrcvd] id 2 len 18
005769: *Jun 24 17:26:30.206 PCTime: ppp76 LCP:    MRU 1400 (0x01040578)
005770: *Jun 24 17:26:30.206 PCTime: ppp76 LCP:    MagicNumber 0x4CDC3223 (0x05064CDC3223)
005771: *Jun 24 17:26:30.206 PCTime: ppp76 LCP:    PFC (0x0702)
005772: *Jun 24 17:26:30.206 PCTime: ppp76 LCP:    ACFC (0x0802)
005773: *Jun 24 17:26:30.206 PCTime: ppp76 LCP: O CONFNAK [ACKrcvd] id 2 len 8
005774: *Jun 24 17:26:30.210 PCTime: ppp76 LCP:    MRU 1500 (0x010405DC)
005775: *Jun 24 17:26:30.210 PCTime: ppp76 LCP: I CONFREQ [ACKrcvd] id 3 len 18
005776: *Jun 24 17:26:30.210 PCTime: ppp76 LCP:    MRU 1400 (0x01040578)
005777: *Jun 24 17:26:30.210 PCTime: ppp76 LCP:    MagicNumber 0x4CDC3223 (0x05064CDC3223)
005778: *Jun 24 17:26:30.210 PCTime: ppp76 LCP:    PFC (0x0702)
005779: *Jun 24 17:26:30.210 PCTime: ppp76 LCP:    ACFC (0x0802)
005780: *Jun 24 17:26:30.210 PCTime: ppp76 LCP: O CONFNAK [ACKrcvd] id 3 len 8
005781: *Jun 24 17:26:30.210 PCTime: ppp76 LCP:    MRU 1500 (0x010405DC)
005782: *Jun 24 17:26:30.214 PCTime: ppp76 LCP: I CONFREQ [ACKrcvd] id 4 len 18
005783: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    MRU 1500 (0x010405DC)
005784: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    MagicNumber 0x4CDC3223 (0x05064CDC3223)
005785: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    PFC (0x0702)
005786: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    ACFC (0x0802)
005787: *Jun 24 17:26:30.214 PCTime: ppp76 LCP: O CONFACK [ACKrcvd] id 4 len 18
005788: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    MRU 1500 (0x010405DC)
005789: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    MagicNumber 0x4CDC3223 (0x05064CDC3223)
005790: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    PFC (0x0702)
005791: *Jun 24 17:26:30.214 PCTime: ppp76 LCP:    ACFC (0x0802)
005792: *Jun 24 17:26:30.214 PCTime: ppp76 LCP: State is Open
005793: *Jun 24 17:26:30.214 PCTime: ppp76 PPP: Phase is AUTHENTICATING, by this end
005794: *Jun 24 17:26:30.222 PCTime: ppp76 MS-CHAP: O CHALLENGE id 1 len 21 from "xxxx3 "
005795: *Jun 24 17:26:30.222 PCTime: ppp76 LCP: I IDENTIFY [Open] id 5 len 18 magic 0x4CDC3223 MSRASV5.10
005796: *Jun 24 17:26:30.222 PCTime: ppp76 LCP: I IDENTIFY [Open] id 6 len 31 magic 0x4CDC3223 MSRAS-0-IBM-T8O9EXO81ZA
005797: *Jun 24 17:26:30.222 PCTime: ppp76 MS-CHAP: I RESPONSE id 1 len 61 from "testowe"
005798: *Jun 24 17:26:30.226 PCTime: ppp76 PPP: Phase is FORWARDING, Attempting Forward
005799: *Jun 24 17:26:30.226 PCTime: ppp76 PPP: Phase is AUTHENTICATING, Unauthenticated User
005800: *Jun 24 17:26:30.226 PCTime: ppp76 PPP: Sent MSCHAP LOGIN Request
005801: *Jun 24 17:26:30.226 PCTime: ppp76 PPP: Received LOGIN Response FAIL
005802: *Jun 24 17:26:30.226 PCTime: ppp76 MS-CHAP: O FAILURE id 1 len 13 msg is "E=691 R=0"
005803: *Jun 24 17:26:30.230 PCTime: ppp76 PPP: Sending Acct Event[Down] id[80]
005804: *Jun 24 17:26:30.230 PCTime: ppp76 PPP: Phase is TERMINATING
005805: *Jun 24 17:26:30.230 PCTime: ppp76 LCP: O TERMREQ [Open] id 2 len 4
005806: *Jun 24 17:26:30.238 PCTime: ppp76 LCP: I TERMACK [TERMsent] id 2 len 4
005807: *Jun 24 17:26:30.238 PCTime: ppp76 LCP: State is Closed
005808: *Jun 24 17:26:30.238 PCTime: ppp76 PPP: Phase is DOWN
005809: *Jun 24 17:26:30.238 PCTime: ppp76 PPP: Send Message[Disconnect]
005810: *Jun 24 17:26:30.238 PCTime: VPDN uid:76 disconnect (AAA) IETF: 17/user-error Ascend: 26/PPP CHAP Fail
005811: *Jun 24 17:26:30.238 PCTime: VPDN uid:76 vpdn shutdown session, result=2, error=6, vendor_err=0, syslog_error_code=8, syslog_key_type=1
005812: *Jun 24 17:26:30.238 PCTime: VPDN uid:76 VPDN/AAA: accounting stop sent
005813: *Jun 24 17:26:30.266 PCTime: VPDN Received L2TUN socket message
I think the problem is creating user password with encryption using MD5.
Why?? Is this normally ??
Seems you're using MSCHAP.
Have you tried PAP and optional encryption just to see if it works?
Federico.
Simply creating user without MD5 encryption of the password works perfectly.
I have Win7 so I was forced to change configuration on MS-CHAP v2
