Centralized (IAS/Radius) Authentication under IDS/IPS 4260
Answered Question
Jun 17th, 2010
All,
I have been tasked with the configuring centralized authentication via IAS for all the IPS/IDS devices in the enterprise.  After much invest I'm almost sure that due to limitations inherent to the device my goal is not obtainable.  However, I am still not 100% sure.  My questions are:
1. Can anyone provide a link or any documentation showing definitively whether or not the IPS 4260 supports IAS/Radius authentication?
     a. If not, what would be a suitable alternative? CSM, etc.?
Correct Answer by Scott Fringer about 6 years 10 months ago
Cisco's IPS sensors do not currently support externally authenticated access.  They will only support
local username/password authentication and role assignment.
Scott
Overall Rating: 5 (2 ratings)
Correct Answer
Scott Fringer Thu, 06/17/2010 - 09:28
  • Cisco Employee,
Scott
trippi Fri, 07/30/2010 - 13:47
This is available with the latest release.
bestsoftware Wed, 11/16/2011 - 15:56
Hi All,
I have several IPS ASA-SSM-10 and IPS 4260, I spent several hours trying to get them to authenticate through MS IAS 2003 R2, I was able to get them authenticated thru SSH but not in ASDM. I really appreciate if anyone have any information how to get these working in ASDM.
Si
Farrukh Haroon Wed, 11/16/2011 - 19:25
  • Red, 2250 points or more
Hello
What version are you running on the IPS?
Login to the CLI and keep running the show events command, then login with HTTPS (IDM) and post the exact error in the event log
Farrukh
bestsoftware Thu, 11/17/2011 - 09:08
Hi Farrukh,
All IPS/IDS are running version 7.0.4. I did what you recommended and below are the logs I captured:
evStatus: eventId=1306479664548993105 vendor=Cisco
  originator:
    hostId: NACAIRVIDLAB1
    appName: cidwebserver
    appInstanceId: 349
  time: 2011/11/17 16:57:45 2011/11/17 16:57:45 UTC
  loginAction: action=loginFailed
    description: User failed to authenticate with the HTTP server
    userName: best\xsxtran
    userAddress: port=64368 10.90.204.17
evStatus: eventId=1306479664548993106 vendor=Cisco
  originator:
    appInstanceId: 349
  time: 2011/11/17 16:57:58 2011/11/17 16:57:58 UTC
    userAddress: port=64369 10.90.204.17
Thanks for all your help
Si
Farrukh Haroon Fri, 11/18/2011 - 23:24
I think I saw the same issue before, in your AAA config on the sensor(s) please change the default user role to administrator.
On the CLI:
service aaa
default-user-role administrator
This can also be done through the GUI (IDM).
Farrukh
bestsoftware Mon, 11/21/2011 - 08:28
Hi Farrukh,
Thanks for helping. I figured out the problem. It was the IOS bug. It worked as soon as I upgraded to version 7.0.6. All my IPS/IDS authenticated through Microsoft Radius now.
Si
Farrukh Haroon Mon, 11/21/2011 - 09:51
I'm glad you have it working now and thanks for sharing with everybody
Farrukh
Related Content
