ACS 5.0.0.21 monitoring and reports database
Jun 17th, 2010
Just installed ACS 5.0.0.21.  Monitoring and reports database was working, but now is not.  When trying to open, I get "Monitoring and reports database currently unavailable.  Trying reconnect in 5 minutes."    From CLI "sho application status acs" gives me the following:
ACS role: PRIMARY
Process 'database'                  running
Process 'management'                running
Process 'runtime'                   running
Process 'adclient'                  running
Process 'view-database'             running
Process 'view-collector'            running
Process 'view-jobmanager'           running
Process 'view-alertmanager'         running
Also, logs show nothing unusual.
Reload of appliance does not help.
Any other way to check why this appears to be unavailable?
p-blalock Thu, 06/17/2010 - 09:41
Cancel that... after 3 system reloads, it finally came back - this is not very comforting since this is a new install and under almost no load at all.
Si Wed, 03/14/2012 - 02:28
We are experiencing this problem now.
"The  monitoring and reports database is currently unavailable. Attempting to  reconnect in 5 seconds.
If  problem persists, please contact your ACS administrator."
This is after a VM fail, any ideas on how to recover this? The 3 reloads didnt cure our problem
S
minkumar Tue, 03/20/2012 - 12:12
  • Silver, 250 points or more
   If the version is ACS 5.0 then You probably are hitting the followin bug:CSCsx43817. I would recomend you upgrading the box to the new version.
Minakshi
Do rate the helpful posts
Si Thu, 03/22/2012 - 09:14
Thanks for your response in the end we had to just rebulid. But ill look into upgrading
S
minkumar Fri, 03/23/2012 - 10:53
Here is the path from here you can downlooad the iso and upgrade the acs:
Login to cisco systems> support> all download>  products>  security> identity management> cisco secure access control  system> cisco secure access 5.x
You would see the link for 5.1 , 5.2 and 5.3
Click on any of the link and you will find the .iso image.
Minakshi
Si Mon, 03/26/2012 - 04:11
Thanks for that. Not sure our maintence supports upgrading to 5.3 but thanks anyway
Si
