LLDP-MIB in a Cat6509 VSS System mit 12.2(33)SXI3 ?
Jun 17th, 2010
Hello together,
we have a Catalyst 6509 VSS 720/10G System with IOS 12.2(33)SXI3 (IP Services SSH).
The Cisco MiB Locator shows that the LLDP-MIB is available for this system. But all
SNMP queries (v1,v2c) for  LLDP-MIB variables shows no results?  The LLDP
commands in the CLI work and give correct results.
Is there someting to mind if one will use the LLDP-MIB in SNMP queries (IOS configuration, SNMP
Version etc.) or gives der MIB Locator a wrong information or is this a problem of the IOS version?
Has anyone tried to query the LLDP MIB in a similar system?
with kind regards
Ulrich Werling
P.S: The same SNMP queries work well with correct results wit a Catalyst 3750E (IOS 12.2(50)SE3).
sbeitzell Thu, 07/29/2010 - 11:06
Giving this one a poke as I have a similar issue.
6509, 12.2(33)SXI4, Advanced IP Services, LLDP on and working from CLI.
Yee-Ting.Li Mon, 08/09/2010 - 18:01
i would also like the 6500's sup720 to support lldp reporting via snmp mibs.
ehoelzle-hcr Tue, 10/19/2010 - 11:40
We see the same issue in both Sup32 and Sup720/VSS configurations.
It would be a fantastic thing if LLDP worked over SNMP.
Eric
