VRF-aware GRE-Tunnel with IPsec
Jun 17th, 2010
I would like to set up an IPsec protected GRE tunnel between PE (3825, 12.4(24)T3) and CE (2851, 12.4(22)T5).
The PE runs multiple VRFs.
PE:
FastEthernet 192.168.1.5/30 in VRF AAA-WAN
Loopback 192.168.2.5/32 in VRF AAA-WAN
Tunnel 192.168.3.5/30 in VRF AAA
CE:
FastEthernet 192.168.1.6/30
Loopback 192.168.2.6/32
Tunnel 192.168.3.6/30
PE (VRF AAA-WAN) and CE run ROUTER EIGRP 19 to establish connectivity between the loopback interfaces, which are the tunnel source and destination. EIGRP neighborship gets established for process 19.
The tunnel interfaces are up/up, but i can't ping between the tunnel interfaces. Removing the tunnel protection does not help, so it does not seem to be an issue regarding IPsec.
Setting the whole thing up without VRFs (in global table on PE) works fine.
Any hints are appreciated.
Robert
hostname PE
ip vrf AAA
rd 10.190.190.1:3600
route-target export 65000:3600
route-target import 65000:3600
ip vrf AAA-WAN
rd 10.190.190.1:3699
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
lifetime 3600
crypto isakmp key SECRET address 0.0.0.0 0.0.0.0
crypto ipsec transform-set AAA-TS esp-aes 256 esp-sha-hmac
crypto ipsec profile AAA-P
set transform-set AAA-TS
interface Loopback3601
ip vrf forwarding AAA-WAN
ip address 192.168.2.5 255.255.255.255
interface Tunnel3601
ip address 192.168.3.5 255.255.255.252
tunnel source Loopback3601
tunnel destination 192.168.2.6
tunnel vrf AAA-WAN
tunnel protection ipsec profile AAA-P
interface FastEthernet1/0
ip address 192.168.1.5 255.255.255.252
router eigrp 19
  no auto-summary
  address-family ipv4 vrf AAA-WAN
   network 192.168.1.4 0.0.0.3
   network 192.168.2.4 0.0.0.3
   no auto-summary
   autonomous-system 19
  exit-address-family
router eigrp 20
no auto-summary
  network 192.168.3.4 0.0.0.3
  no auto-summary
  autonomous-system 20
exit-address-family
hostname CE
encr aes 256
group 5
lifetime 3600
ip address 192.168.2.6 255.255.255.255
ip address 192.168.3.6 255.255.255.252
tunnel destination 192.168.2.5
interface GigabitEthernet0/1
ip address 192.168.1.6 255.255.255.252
router eigrp 19
no auto-summary
router eigrp 20
no auto-summary
PE#sh int tu3601
Tunnel3601 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 192.168.3.5/30
  MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 192.168.2.5 (Loopback3601), destination 192.168.2.6
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "AAA-P")
  Last input 00:25:13, output never, output hang never
  Last clearing of "show interface" counters 03:44:55
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 353
  Queueing strategy: fifo (QOS pre-classification)
  Output queue: 0/0 (size/max)
     5 packets input, 620 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     5 packets output, 620 bytes, 0 underruns
     0 unknown protocol drops
PE#sh ip route vrf AAA-WAN
     192.168.1.0/30 is subnetted, 1 subnets
C       192.168.1.4 is directly connected, FastEthernet1/0
     192.168.2.0/32 is subnetted, 2 subnets
D       192.168.2.6 [90/770560] via 192.168.1.6, 00:24:42, FastEthernet1/0
C       192.168.2.5 is directly connected, Loopback3601
     192.168.3.0/30 is subnetted, 1 subnets
C       192.168.3.4 is directly connected, Tunnel3601
PE#ping vrf AAA-WAN 192.168.1.6
Sending 5, 100-byte ICMP Echos to 192.168.1.6, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
PE#ping vrf AAA-WAN 192.168.2.6
Sending 5, 100-byte ICMP Echos to 192.168.2.6, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
PE#ping vrf AAA 192.168.3.6
Sending 5, 100-byte ICMP Echos to 192.168.3.6, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CE#sh int tu3601
  Hardware is Tunnel
  Internet address is 192.168.3.6/30
  Keepalive not set
  Tunnel source 192.168.2.6 (Loopback3601), destination 192.168.2.5
  Tunnel TTL 255
  Last input 00:31:22, output never, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 82
CE#sh ip route
C       192.168.1.4 is directly connected, GigabitEthernet0/1
C       192.168.2.6 is directly connected, Loopback3601
D       192.168.2.5 [90/770560] via 192.168.1.5, 00:28:51, GigabitEthernet0/1
CE#ping 192.168.1.5
Sending 5, 100-byte ICMP Echos to 192.168.1.5, timeout is 2 seconds:
CE#ping 192.168.2.5
Sending 5, 100-byte ICMP Echos to 192.168.2.5, timeout is 2 seconds:
CE#ping 192.168.3.5
Sending 5, 100-byte ICMP Echos to 192.168.3.5, timeout is 2 seconds:
belovell Fri, 06/25/2010 - 09:48
This looks broken to me.
Based on your configs and output this looks like it should work.
-Ben
rupert.finnigan Mon, 10/04/2010 - 13:34
Hi Robert,
Did you manage to get to the bottom of this?
I'm trying the achieve the same thing - Tunnel Source interfaces as Loopbacks in a VRF, Tunnel interfaces in the Global table.
Tunnels get shown as up, but no traffic. I run OSPF over these tunnels - when they're all in the Global table all works fine, when in the VRF no traffic passes.
Interesting that I'm using the same IOS version as you - possible IOS bug?
Be interested to know if you've made progress with this.
Rupes
Gregory Camp Mon, 10/04/2010 - 17:44
  • Cisco Employee,
The PE configs are wrong.
See the changes below.
no crypto isakmp key SECRET address 0.0.0.0 0.0.0.0
crypto keyring AAA-K vrf AAA-WAN
  pre-shared-key address 0.0.0.0 0.0.0.0 key SECRET
crypto isakmp profile AAA-I
  keyring AAA-K
  match identity address 0.0.0.0 0.0.0.0 AAA-WAN
  vrf AAA-WAN
set isakmp-profile AAA-I
lmcruzhsa Wed, 10/13/2010 - 14:41
I am  not able to do ping between tunnel interfaces, did you find the solution?
I was doing the same, move the tunnels to the wan (no result), removing ipsec makes it work.
I use "tunnel mode ipsec ipv4" instead of GRE.
Config is exactly the same but I dont use EIGRP just static routing,
Biggest problem is: tunnels are up/up, crypt engines are talking, so ipsec looks ok with the commands and SAs and all those things, but not ping over the tunnel interfaces.
Some light will be very appreciated here.
Related Content
