Any ideas why a WS-C3550-48-SMI won't show any rate stats on the interfaces?
We've set the interface using 'load-interval 30' and while the interval has change the rate stats are constant at 0 bit/sec I/O.
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 20:28 by gereddy
Image text-base: 0x00003000, data-base: 0x012A99FC
ROM: Bootstrap program is C3550 boot loader
c3550 uptime is 15 weeks, 3 days, 17 hours, 40 minutes
System image file is "flash:c3550-ipservicesk9-mz.122-44.SE6/c3550-ipservicesk9-mz.122-44.SE6.bin"
Model number: WS-C3550-48-SMI
FastEthernet0/43 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0009.b7ed.db80 (bia 0009.b7ed.db80)
  Internet address is 202.0.23.129/29
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 0/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:51:30, output 00:00:02, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     468905 packets input, 309350575 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     441213 packets output, 262767891 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
Matt
