EtherChannel Question
dvanzee
Level 2
Level 2
When I run the
show etherchannel port
                Channel-group listing:
Group: 9
                Ports in the group:
Port: Gi1/0/51
Port state    = Up Mstr In-Bndl
Channel group = 9           Mode = On              Gcchange = -
Port-channel  = Po9         GC   =   -             Pseudo port-channel = Po9
Port index    = 0           Load = 0x00            Protocol =    -                                                <<<<I would expect to see LACP or PagP here.  Because it is not listed here, which protocol is currently running if any? Is this etherchannel functioning correctly?
show etherchannel 9 port-channel
                Port-channels in the group:
Port-channel: Po9
Age of the Port-channel   = 248d:23h:18m:06s
Logical slot/port   = 10/9          Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi1/0/51 On                 0
  0     00     Gi2/0/50 On                 0
Time since last port bundled:    186d:04h:28m:05s    Gi1/0/51
Time since last port Un-bundled: 186d:04h:59m:43s    Gi2/0/50
Config
interface Port-channel9
switchport trunk allowed vlan 41,51,71,101,254
switchport mode trunk
interface GigabitEthernet1/0/51
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
channel-group 9 mode on
Thanks for the help.
10 Replies 10
By chosing the mode on you have forced the channel to be formed. Not using either pagp or lacp.
-Todd
nelson.garcia
If I may add to Todd's correct point, PagP and LACP are negotiation protocols just as DTP is is a negotiation protocol used to set up trunks. When you set links to "On" as you have, you've pretty much excluded any type of negotiation, thus, the protocols are not used.
So with the config listed below I am using basic "etherchannel protocol".  Correct?
Tricky question. Not sure if you would call it a protocol as much as technology.
Are there any issues with this configuration? Are there pro/con's going with PagP or Lacp over my current configuration?
Not necessarily, having them "on" doesn't hurt at all. PagP (Port Aggregation Protocol) is a Cisco proprietary protocol used to form etherchannel links between Cisco switches. LACP (Link Aggregation Control Protocol) is a protocol used to for etherchannels between Cisco switches and switches from other vendors that support LACP.
Each protocol supports 4 modes.
PagP - On, Off, Desirable, Auto
LACP, On, Off, Active, Passive
(Correct me if I'm wrong)
I know with LACP you can configure thresholds (minimum links) which would allow you to determine how many links would be acceptable to lose before your etherchannel will shutdown.  Thereby forcing traffic to route to an alternative path. This would be good for latency sensitive applications. So you can't do this with the configuration you have. The etherchannel you have will stay up as long as you have active links in it.
Also, with LACP I believe you can define standby links to use in the etherchannel if any links in the "active" bundle fail. With PagP all links are "active" or "on".
Just read that somewhere, please correct me if I'm wrong.
In a nutshell there is nothing wrong with the configuration you have. We use this this configuration all the time. Basically when you configure the etherchannel you looking for aggregate bandwidth and thats what you are getting.
My 2 cents.
Here is the info from a Cisco Document....
EtherChannel On Mode
EtherChannel
on mode can be used to manually configure an EtherChannel. The on mode forces a port
to join an EtherChannel without negotiations. The
on mode can be useful if the remote device does not
support PAgP or LACP. In the
on mode, a usable EtherChannel exists only when the switches at both
ends of the link are configured in the
on mode.
Ports that are configured in the
on mode in the same channel group must have compatible port
characteristics, such as speed and duplex. Ports that are not compatible are suspended, even though they
on mode.
Caution
You should use care when using the on mode. This is a manual configuration, and ports on both ends of
the EtherChannel must have the same configuration. If the group is misconfigured, packet loss or
spanning-tree loops can occur.
Please rate posts that help,
Mike
