Hitesh Vinzoda Thu, 06/17/2010 - 22:52
Can you rephrase the sentence or elaborate the scenario, what exactly you want to achieve...?
Hitesh Vinzoda
Giuseppe Larosa Fri, 06/18/2010 - 05:46
Hello Pratibha,
if you mean that you would like to use two different OSPF processes one running INSIDE the MGRE virtual flat topology and one running on real infrastructure in a lab environment.: this is possible.
if you would like to run two OSPF processes on the MGRE interface the answer is negative unless you use different area-ids
OSPF version2 does not export OSPF process-id in OSPF hellos so you cannot run two OSPF processes using the same area-id.
But even using different areas could be a big problem as the router cannot know to which process to send the packet
I do not recommend to try to use it, but if you are in a lab you can test it by yourself.
your best choice would be to deploy two DMVPN clouds with two mGRE and on mGREx you run ospf process x and on mGRE y you run OSPF process y.
Hope to help
Giuseppe
Ahmed Shaheen Fri, 06/18/2010 - 15:24
hello giuslar,
i am having a live scenario,
i am having now main branch with 25 nodes attached with ip connect provided from my ISP connecting each with OSPF process 10.
the config is in short as following:
int tunel 1
ip address 1.1.1.1 255.255.255.0
-etc-
int fa0/0 <-- LAN
ip address 10.100.100.1 255.255.255.0
int fa0/1 <-- WAN
ip address 10.211.211.62 255.255.255.252
rotuer ospf 10
network 1.1.1.1 0.0.0.0 area 0
network LAN area 0
network WAN area 0
nothing else configured to be mentioned. (no static routes or default rules)
lets go step by step,
based on the above basic config; by showing crypto isakmp sa it shows that the tunnel is ACTIVE but traffic is exposed to my ISP as when i show ip route i can see all other branches and nodes being published from my ISP (10.211.211.61) not from my tunnel interface.
i am sure the DMVPN tunnel is not working as there is no traffic coming or going through it. how can this problem be solved?
keeping in mind that i can't change the process ospf 10 as it is the routing protocol agreed on with my ISP.
to solve this problem i've tried to have 2 OSPF processes but i am failing to make it happen.
if you need more info please let me know.
Giuseppe Larosa Wed, 07/07/2010 - 00:13
Hello Shaheen,
you need to use two OSPF processes:
OSPF process 10 has to be used only for the link to the provider and eventually a loopback interface to be used as IPSec endpoint
example:
access link in net 192.168.3.0/30
loop 192.168.3.254/32
internal networks:
10.10.0.0/16
DMVPN IP subnet: 172.18.20,0/24
OSPF process 20 for DMVPN
router ospf 10
network 192.168.3.0 0.0.03 area 0
network 192.168.3.254 0.0.0.0 area 0
router ospf 20
network 172.18.20.0 0.0.0.255 area 0
network 10.10.0.0 0.0.255.255 area 1
your main process becomes process 20, OSPF 10 is only used with SP
you need a clear separation between internal networks to be only advertised on OSPF 20 to send and receive traffic over the DMVPN
Hope to help
Giuseppe
Giuseppe Larosa Wed, 07/07/2010 - 01:46
Hello Shaheen,
>> dont i need to redistribute any process to the other?
don't do that keep them separated or you may be lost
Hope to help
Giuseppe
