Multicasting over GRE
Answered Question
Jun 17th, 2010
If we configure GRE tunnel between over the network which is not Multicasting enabled. But we need to send multicasting packets over GRE tunnel.
If we run routing protocol on the GRE tunnel it will form the neighbor relationship. Will it encapsulate the multicasting packets?
Please share the experience.
Thanks in advance
Subodh
Correct Answer by Hitesh Vinzoda about 6 years 7 months ago
Make sure that RPF is done over the GRE tunnel, otherwise multicast will not work...
Hitesh Vinzoda
Pls rate useful posts.
Correct Answer by Tod Larson about 6 years 7 months ago
Multicast over GRE works great.  We use the ip pim sparse-dense-mode command on each end of the tunnel and performs great.
Overall Rating: 5 (2 ratings)
Correct Answer
Tod Larson Thu, 06/17/2010 - 19:24
Correct Answer
Hitesh Vinzoda Thu, 06/17/2010 - 22:31
Hitesh Vinzoda
bapatsubodh Fri, 06/18/2010 - 03:47
Thanks guys !!
By RPF you mean reverse path  forwarding ..am I correct ..
