Wireless - show dot11 statistics client-traffic
Jun 18th, 2010
Below is the output from the above command:
1-001d.e049.f5a7 pak in 25 bytes in 3272 pak out 8 bytes out 1364
      dup 0 decrpyt err 0 mic mismatch 0 mic miss 0
      tx retries 0 data retries 0 rts retries 0
      signal strength 72 signal quality 27
But I am unable to find any documentation of the signal strength and signal quality?
Does anyone have a chart or docs as to what the figures mean? is it out of 100 and 100 been best etc?
Many Thanks
Leo Laohoo Fri, 06/18/2010 - 16:30
You want the RSSI (Radio Signal Strength Indicator) and the SNR (Signal-to-Noise Ratio) of a particular client?
You have to run one or two commands then.  The first one is "sh dot11 s".  This will show you the wireless MAC address of a client.  Copy-n-Paste the MAC address of your choice and use the command "sh dot11 s ".
Does this answer your question?
Please don't forget to rate useful posts.  Thanks.
Trending Topics - Security & Network
