Error loading Diccionaries
Jun 18th, 2010
These days I'm provisioning 100 spa922 and 100 spa942.The provision run ok but now I have a problem with dictionaries because 75% of phones don't change the language.
I put a syslog server and the phones show this errors:
un 18 09:10:59 10.1.1.26 Dict_D> Copy scp is "serv=tftp://10.1.1.1/;d0=English;x0=enS_v101.xml;d1=Spanish;x1=esS_v101.xml", before filter
Jun 18 09:10:59 10.1.1.26 Dict_D> After update status filter, the storeBuf is  "serv=tftp://10.1.1.1/;d0=English;x0=enS_v101.xml;d1=Spanish;x1=esS_v101.xml"
Jun 18 09:10:59 10.1.1.26 Dict_D> Start DICT_tftpMain process, status is 0
Jun 18 09:10:59 10.1.1.26 Dict_D> Current scp is serv=tftp://10.1.1.1/;d0=English;x0=enS_v101.xml;d1=Spanish;x1=esS_v101.xml
Jun 18 09:10:59 10.1.1.26 Dict_D> After filter, copy scp is "serv=tftp://10.1.1.1/;d0=English;x0=enS_v101.xml;d1=Spanish;x1=esS_v101.xml"
Jun 18 09:10:59 10.1.1.26 Dict_N> Same url script with copy script; do not update all
Jun 18 09:10:59 10.1.1.26 Dict_N> Parse current dict script succeeded
Jun 18 09:10:59 10.1.1.26 Dict_D> DICT_serverScp ip address is 10.1.1.1
Jun 18 09:10:59 10.1.1.26 Dict_N> Need not update font file!
Jun 18 09:10:59 10.1.1.26 Dict_N> There are 2 dict totally, dict[0]  is "English"
Jun 18 09:10:59 10.1.1.26 Dict_N> There are 2 dict totally, dict[1]  is "Spanish"
Jun 18 09:10:59 10.1.1.26 ---------- sdictEnable: Spanish, DICT_scpDisplay(0): English
Jun 18 09:10:59 10.1.1.26 Dict_D> There are 2 dict totally, dict[0]  is "English"
Jun 18 09:10:59 10.1.1.26 ---------- sdictEnable: Spanish, DICT_scpDisplay(1): Spanish
Jun 18 09:10:59 10.1.1.26 Dict_D> There are 2 dict totally, dict[1]  is "Spanish"
Jun 18 09:10:59 10.1.1.26 Dict_N> User select "Spanish" language
Jun 18 09:10:59 10.1.1.26 ---------- g_dict_enable[0]: 1, : 2004500
Jun 18 09:10:59 10.1.1.26 Dict_D> Store pDictTftp->prev_dict_enable: 1
Jun 18 09:10:59 10.1.1.26 Dict_N> !!!OK EXIT TFTP main process
Jun 18 09:10:59 10.1.1.26 DDE12 0 1
Jun 18 09:10:59 10.1.1.26 dictTftpNum: 0
Jun 18 09:10:59 10.1.1.26 paylen: 44018
Jun 18 09:10:59 10.1.1.26 DICT_verify: 0
Jun 18 09:10:59 10.1.1.26 paylen: 23168
Jun 18 09:10:59 10.1.1.26 3.0 1fef50 504
Jun 18 09:10:59 10.1.1.26 DDE10 0 1
Jun 18 09:10:59 10.1.1.26 Dict_N> DICT feature is enabled!
Jun 18 09:10:59 10.1.1.26 DDE13 0 1
I  tested with several versions of the dictionary but don't work.
The xml is tested in other phones and run ok, but i attach the configuratión:
This is the Dictionary server conf in spa942.cfg:
<Dictionary_Server_Script ua="na">  serv=tftp://10.1.1.1/;d0=English;x0=enS_v101.xml;d1=Spanish;x1=esS_v101.xml </Dictionary_Server_Script>
<Language_Selection ua="na"> Spanish
</Language_Selection>
Any solution?
Alberto Montilla Mon, 06/21/2010 - 02:46
Dear Sir;
Did you modify the dictionaries at all?
There are several things that may be affecting the download:
(1) Reachability of the tftp server
(2) You changed the dictionaries, this cannot be done, as this as signed, so content cannot be modified
(3) You are trying to update the dictionaries (from existing ones) but the filenames are the same. On the dictionary logic, if filename is the same, it does not trigger an update but keep the old one.
I suggest to check the above.
Alberto
AlbertoQuobis Mon, 06/21/2010 - 04:32
1) Tftp server run ok.
2) The dictionaries is not modified.
3) Change the filenames and don't run, the syslog show this:
Dict_N> Store the "/espanol.xml" dict to flash ok, total_size: 44018 bytes written
  ---------- g_dict_enable[0]: 0, : 2935860
  DDE12 0 1
  dictTftpNum: 0
  paylen: 0
  Dict_N> Dict flash[1] err happened, check errcode1=1
  total_size: 107882, max expected_size: 60000
  Dict_N> error = DICT_VERIFY_REC_SIZE
  Dict_D> _DICT_verify(), err, return val [3]
  DICT_verify: 3
  Dict_N> Dict flash[1] err happened, check errcode2=3
  Dict_N> Dict load dictionary data, err happened, erase the dictionary[1]
  fu:1:5e3f, 7.23.2 1
  paylen: 44018
  Dict_N> Dict flash[0] err happened, check errcode1=3
  DICT_verify: 3
  Dict_N> Dict flash[0] err happened, check errcode2=3
  Dict_N> Dict load dictionary data, err happened, erase the dictionary[0]
  Dict_N> Err happend when load dictionary from flash, function SG_DictInit
  3.0 3086f0 897
  DDE11 0 0
  Dict_N> DICT init err, use dummy dict and map first
  DDE13 0 0
Where can I see the information for this errors?
Regards.
