06-18-2010 01:54 AM - edited 03-06-2019 11:38 AM
Hi all
When configuring a trunk from a Nortel device using MLT, to a cisco switch using fixed port channel, Is this OK? I have it working at the moment and there seems no issue, just wanted to make sure its fine.
cheers
Carl
Solved! Go to Solution.
06-18-2010 02:40 AM
Sure does, I have a Nortel 8600 MLT connected to a 3750 etherchannel trunk, works just as it should.
06-18-2010 02:37 AM
Hi all
cheers
Carl
Hi Carl,
It is tested ok by Nortel that MLT works fine with cisco etherchannel,check out the below link for confirmation.
http://www.nortel.com/products/01/passport/2500/collateral/nn123232.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
06-18-2010 02:40 AM
06-18-2010 04:36 PM
Hi there
Did you just add a normal mlt and a normal fixed etherchannel, or did you have to use LACP?
Cheers
Carl
06-21-2010 02:58 AM
Yeah the Cisco is just a normal Etherchannel adn teh Nortel I believe is too, although a consultant set this up, all I can see is this on the switch:
Nortel
mlt 12 create
mlt 12 add ports 2/45
mlt 12 perform-tagging enable
mlt 12 smlt create smlt-id 12
and something like
vlan 105 create byport 1 name "givemeaname" color 6
vlan 105 add-mlt 12
vlan 105 ports add 1/1-1/2,1/45,2/1-2/2,2/45 member portmember
vlan 105 ip create 192.168.26.254/255.255.255.0 mac_offset 19
vlan 105 ip pim enable
vlan 105 ip ospf enable
vlan 105 ip ospf authentication-type simple
vlan 105 ip ospf authentication-key ***
vlan 105 ip rsmlt enable
vlan 105 ip rsmlt holdup-timer 9999
Please rate if of any help
