Italian ISDN Incoming Called Party Problem
Jun 18th, 2010
I have a branch ofice in Italy that uses IP phones connected back to a CCM in London via a MPLS. Incoming calls to the Italian office come in to the ISDN which is connected to a Cisco 2921 router. They can recieive international inbound calling no problem, however they cannot receive national inbound calling (ie Italy to Italy). There is no problem with outbound calling or internal dialling.
I have performed some Q931 and Q921 debugging and have noticed that the last 2 digits are missing on the called party's number (obviously the reason why the call isn't being established). When a call is received from an international number all digits on the called party's number are seen perfectly. After reading several artciles and tweaking dial-peers and trying to account for ISDN overlapping I am now stuck. What confuses me even more is that after making all my changes I have now been informed that although the inital Italy to Italy inbound call doesn't work, if the calling party hits redial they can get through.
I have posted the dial-peers and voice translation rules below. Any ideas would be fantastic...
voice translation-rule 100
rule 1 /^.*\(....\)/ /\1/
voice translation-rule 101
rule 1 /^2\(...\)$/ /622\1/
voice translation-rule 200
rule 1 /^$/ //
rule 2 /\(.+\)/ /00\1/ plan national national
rule 3 /\(.+\)/ /000\1/ plan unknown unknown
rule 4 /\(.+\)/ /00\1/ type national national
rule 5 /\(.+\)/ /000\1/ type international international
voice translation-rule 300
rule 1 /^\(9...\)$/ /00044207954\1/
rule 2 /^\(68..\)$/ /00044207743\1/
rule 3 /^\(44..\)$/ /00044161242\1/
voice translation-profile PSTN-IN
translate calling 200
translate called 100
voice translation-profile PSTN-OUT
translate calling 101
interface Serial0/0/0:15
description *** Telecom Italia ISDN DDI range 02 7262 2711-99 ***
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn switch-type primary-net5
isdn overlap-receiving T302 10000
isdn incoming-voice voice
isdn outgoing display-ie
isdn outgoing ie redirecting-number
no cdp enable
voice-port 0/0/0:15
translation-profile incoming PSTN-IN
translation-profile outgoing PSTN-OUT
echo-cancel coverage 48
no vad
cptone IT
dial-peer voice 1 pots
description *** INBOUND POTS PEER ***
destination-pattern 2T
incoming called-number .%
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 voip
description *** INBOUND VOIP PEER ***
voice-class codec 1
dtmf-relay h245-alphanumeric
fax rate disable
ip qos dscp cs3 signaling
no vad
dial-peer voice 8850 voip
tone ringback alert-no-PI
description *** FIRST CCM NODE ***
destination-pattern 27..
progress_ind setup enable 3
progress_ind alert enable 8
session target ipv4:10.254.16.58
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 8851 voip
description *** SECOND CCM NODE ***
preference 1
session target ipv4:10.254.16.59
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 999 pots
description *** 999 OUT PEER ***
destination-pattern 0999
port 0/0/0:15
forward-digits 3
dial-peer voice 112 pots
description *** 0112 OUT PEER ***
destination-pattern 0112
port 0/0/0:15
forward-digits 3
dial-peer voice 9 pots
description *** ALL OUT PEER ***
destination-pattern 0T
port 0/0/0:15
daniel.needleman Fri, 06/18/2010 - 03:47
Sorry, forgot to put that
Jun 17 15:56:17.510: ISDN Se0/0/0:15 Q931: SETUP pd = 8  callref = 0x4800
Bearer Capability i = 0x8090A3
  Standard = CCITT
  Transfer Capability = Speech
  Transfer Mode = Circuit
  Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838F
  Preferred, Channel 15
Calling Party Number i = 0x2183, '522515794'
  Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2726227'
High Layer Compat i = 0x9181
Jun 17 15:56:17.510: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=85
Jun 17 15:56:17.510: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xC800 callID = 0x02D5 switch = primary-net5 interface = User
Jun 17 15:56:17.510: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=86 nr=85
Jun 17 15:56:17.510: ISDN Se0/0/0:15 Q931: SETUP_ACK pd = 8  callref = 0xC800
Channel ID i = 0xA9838F
  Exclusive, Channel 15
Jun 17 15:56:17.510: //-1/B2EC843E82D6/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=00522515794
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=6227
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun 17 15:56:17.510: //-1/B2EC843E82D6/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x30CB6670, Call Info(
   Calling Number=00522515794,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=6227(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
   Interface Type=13, Protocol=0
Jun 17 15:56:17.510: //-1/B2EC843E82D6/CCAPI/ccCheckClipClir:
   In: Calling Number=00522515794(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Calling Party number is Network Provided
   Out: Calling Number=00522515794(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Jun 17 15:56:17.510: //1978/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=2
Jun 17 15:56:17.510: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 17 15:56:17.510: :cc_get_feature_vsa malloc success
Jun 17 15:56:17.510:  cc_get_feature_vsa count is 3
Jun 17 15:56:17.510: :FEATURE_VSA attributes are: feature_name:0,feature_time:709286224,feature_id:1978
Jun 17 15:56:17.510: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Jun 17 15:56:17.510:  call_init_entry calle is 2A378BA8,callid is 1978
Jun 17 15:56:17.510: //1978/B2EC843E82D6/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=1978
Jun 17 15:56:17.510: //1978/B2EC843E82D6/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=00522515794(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=6227(TON=National, NPI=ISDN))
Jun 17 15:56:17.510: //1978/B2EC843E82D6/CCAPI/cc_process_call_setup_ind:
   Event=0x29E22368
Jun 17 15:56:17.510: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=6227, Call Transfer Consult Id=
Jun 17 15:56:17.510: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
Jun 17 15:56:17.514: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
Jun 17 15:56:17.514: Comparing SSOpCode; 0x50 and 0x0
Jun 17 15:56:17.514: Comparing SSOpCode; 0x12 and 0x0
Jun 17 15:56:17.514: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 6227
Jun 17 15:56:17.514: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   No Matching Node
Jun 17 15:56:17.514: //1978/B2EC843E82D6/CCAPI/ccCallSetContext:
   Context=0x2A39EB64
Jun 17 15:56:17.514: //1978/B2EC843E82D6/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 1978 with tag 1 to app "_ManagedAppProcess_Default"
Jun 17 15:56:17.514: //1978/B2EC843E82D6/CCAPI/ccCallSetupAck:
   Call Id=1978
Jun 17 15:56:17.514: //1978/B2EC843E82D6/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
   Call Transfer Reset
Jun 17 15:56:17.514: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
Jun 17 15:56:17.514: //1978/B2EC843E82D6/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Start Calling Accounting;
   Call Entry(Incoming=TRUE)
   Cause Value=1, Call Entry(Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Jun 17 15:56:17.514: //1978/B2EC843E82D6/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jun 17 15:56:17.514: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=87 nr=85
Jun 17 15:56:17.514: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8  callref = 0xC800
Cause i = 0x8081 - Unallocated/unassigned number
Jun 17 15:56:17.530: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=85 nr=88
Jun 17 15:56:17.530: ISDN Se0/0/0:15 Q931: RELEASE pd = 8  callref = 0x4800
Jun 17 15:56:17.530: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=86
Jun 17 15:56:17.534: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=88 nr=86
Jun 17 15:56:17.534: ISDN Se0/0/0:15 Q931: RELEASE_COMP pd = 8  callref = 0xC800
Jun 17 15:56:17.534: //1978/B2EC843E82D6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30CB6670, Tag=0x0, Call Id=1978,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jun 17 15:56:17.534: //1978/B2EC843E82D6/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
Jun 17 15:56:17.534: //1978/B2EC843E82D6/CCAPI/cc_delete_call_entry:
   ccFreeRawMsgInfo=0x3008B04C
Jun 17 15:56:17.534: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 17 15:56:17.534: :cc_free_feature_vsa freeing 2A46D948
Jun 17 15:56:17.534:  vsacount in free is 2
   Total Call Count=2, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=1
   Deleting profileTable[0x29C44254]
Jun 17 15:56:17.534: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
Jun 17 15:56:17.534: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
Jun 17 15:56:17.730: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=89
Jun 17 15:56:27.530: ISDN Se0/0/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=89
Jun 17 15:56:27.530: ISDN Se0/0/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=86
Jun 17 15:56:35.678: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=86 nr=89
Jun 17 15:56:35.678: ISDN Se0/0/0:15 Q931: SETUP pd = 8  callref = 0x5200
  Standard = CCITT
Channel ID i = 0xA18381
Called Party Number i = 0xA1, '272622724'
Jun 17 15:56:35.678: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=87
Jun 17 15:56:35.678: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xD200 callID = 0x02D6 switch = primary-net5 interface = User
Jun 17 15:56:35.678: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=89 nr=87
Jun 17 15:56:35.678: ISDN Se0/0/0:15 Q931: SETUP_ACK pd = 8  callref = 0xD200
Channel ID i = 0xA98381
Jun 17 15:56:35.678: //-1/BDC0B60282D7/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=2724
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun 17 15:56:35.678: //-1/BDC0B60282D7/CCAPI/cc_api_call_setup_ind_common:
   Called Number=2724(TON=National, NPI=ISDN),
Jun 17 15:56:35.678: //-1/BDC0B60282D7/CCAPI/ccCheckClipClir:
Jun 17 15:56:35.678: //1979/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=2
Jun 17 15:56:35.678: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 17 15:56:35.678: :cc_get_feature_vsa malloc success
Jun 17 15:56:35.682:  cc_get_feature_vsa count is 3
Jun 17 15:56:35.682: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 17 15:56:35.682: :FEATURE_VSA attributes are: feature_name:0,feature_time:709286224,feature_id:1979
Jun 17 15:56:35.682: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Jun 17 15:56:35.682:  call_init_entry calle is 2A37DE90,callid is 1979
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=1979
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=2724(TON=National, NPI=ISDN))
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/cc_process_call_setup_ind:
   Event=0x29E22368
Jun 17 15:56:35.682: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=2724, Call Transfer Consult Id=
Jun 17 15:56:35.682: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
Jun 17 15:56:35.682: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
Jun 17 15:56:35.682: Comparing SSOpCode; 0x50 and 0x0
Jun 17 15:56:35.682: Comparing SSOpCode; 0x12 and 0x0
   Try with the demoted called number 2724
   No Matching Node
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/ccCallSetContext:
   Context=0x2A39B24C
   >>>>CCAPI handed cid 1979 with tag 1 to app "_ManagedAppProcess_Default"
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/ccCallSetupAck:
   Call Id=1979
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/cc_api_set_transfer_info:
   Call Transfer Reset
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=8850, Params=0x2A3A37D4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/ccCheckClipClir:
   Destination Pattern=27.., Called Number=2724, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=BDC0B602-795F-11DF-82D7-68EFBD1BF920, Outgoing Dial-peer=8850
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=2724
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x30A6DF5C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=00522515794,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=2724(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=8850, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jun 17 15:56:35.682: //1980/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=2, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
Jun 17 15:56:35.682: :cc_get_feature_vsa malloc success
Jun 17 15:56:35.682:  cc_get_feature_vsa count is 4
Jun 17 15:56:35.682: :FEATURE_VSA attributes are: feature_name:0,feature_time:709286448,feature_id:1980
Jun 17 15:56:35.682:  call_init_entry calle is 2A379780,callid is 1980
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=1979, Bindee Call Id=1980
Jun 17 15:56:35.682: //1980/BDC0B60282D7/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=1980
Jun 17 15:56:35.682: //1980/BDC0B60282D7/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/ccCallSetupRequest:[email protected]
Jun 17 15:56:35.682: //1980/BDC0B60282D7/CCAPI/ccCallSetContext:
   Context=0x2A3A3784
Jun 17 15:56:35.682: //1979/BDC0B60282D7/CCAPI/ccSaveDialpeerTag:
Jun 17 15:56:35.682: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
Jun 17 15:56:35.682: //1980/BDC0B60282D7/CCAPI/cc_incr_if_call_volume:
   Remote IP Address=10.254.16.58, Hwidb=GigabitEthernet0/1
   Total Call Count=2, Voip Call Count=2, MMoip Call Count=0
Jun 17 15:56:35.766: //1980/BDC0B60282D7/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 2)
Jun 17 15:56:35.766: //1980/BDC0B60282D7/CCAPI/cc_api_call_proceeding:
   Interface=0x30A6DF5C, Progress Indication=NULL(0)
Jun 17 15:56:35.766: //1980/BDC0B60282D7/CCAPI/cc_api_call_proceeding:[email protected]
Jun 17 15:56:35.766: //1979/BDC0B60282D7/CCAPI/ccCallProceeding:
Jun 17 15:56:35.766: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=90 nr=87
Jun 17 15:56:35.766: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8  callref = 0xD200
Jun 17 15:56:35.770: //1980/BDC0B60282D7/CCAPI/cc_api_set_called_ccm_detected:
Jun 17 15:56:35.770: //1980/BDC0B60282D7/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Jun 17 15:56:35.770: //1980/BDC0B60282D7/CCAPI/cc_api_call_alert:
   Interface=0x30A6DF5C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jun 17 15:56:35.770: //1979/BDC0B60282D7/CCAPI/ccCallAlert:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jun 17 15:56:35.770: //1979/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A3860D8, callID1=0x7BB, callID2=0x7BC, tag=0x0)
   (confID=0x2A3860D8, callID1=0x7BB, gcid=BDC0B602-795F11DF-82D768EF-BD1BF920, tag=0x0)
Jun 17 15:56:35.770: //1980/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A3860D8, callID2=0x7BC, gcid=BDC0B602-795F11DF-82D768EF-BD1BF920, tag=0x0)
Jun 17 15:56:35.770: //1979/BDC0B60282D7/CCAPI/ccConferenceCreate:
   Conference Id=0x2A3860D8, Call Id1=1979, Call Id2=1980, Tag=0x0
Jun 17 15:56:35.770: //1979/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2A2, Source Interface=0x30CB6670, Source Call Id=1979,
   Destination Call Id=1980, Disposition=0x0, Tag=0xFFFFFFFF
Jun 17 15:56:35.770: //1980/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jun 17 15:56:35.770: cc_api_get_xcode_stream : 4534
Jun 17 15:56:35.770: //1980/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2A2, Source Interface=0x30A6DF5C, Source Call Id=1980,
   Destination Call Id=1979, Disposition=0x0, Tag=0x0
Jun 17 15:56:35.770: //1979/BDC0B60282D7/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2A2, Destination Call Id=1980)
Jun 17 15:56:35.770: //1980/BDC0B60282D7/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2A2, Destination Call Id=1979)
Jun 17 15:56:35.770: //1979/BDC0B60282D7/CCAPI/cc_api_caps_ind:
   Destination Interface=0x30A6DF5C, Destination Call Id=1980, Source Call Id=1979,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jun 17 15:56:35.774: //1979/BDC0B60282D7/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2A2, Call Id1=1979, Call Id2=1980
Jun 17 15:56:35.774: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=91 nr=87
Jun 17 15:56:35.774: ISDN Se0/0/0:15 Q931: ALERTING pd = 8  callref = 0xD200
Progress Ind i = 0x8188 - In-band info or appropriate now available
Jun 17 15:56:35.882: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=92
Jun 17 15:56:36.002: //1980/BDC0B60282D7/CCAPI/cc_api_set_called_ccm_detected:
Jun 17 15:56:36.002: //1980/BDC0B60282D7/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x30A6DF5C, Call Id=1980
Jun 17 15:56:36.002: //1980/BDC0B60282D7/CCAPI/cc_api_call_notify:[email protected]
Jun 17 15:56:36.002: //1980/BDC0B60282D7/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Jun 17 15:56:36.002: //1980/BDC0B60282D7/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Jun 17 15:56:36.002: //1979/BDC0B60282D7/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=1979
vbiccarino Fri, 07/10/2015 - 02:20
Daniel
Did you ever get this resolved? I have the same issue on a site in Italy and would be interested how you fixed it.
Cheers Vince
Paolo Bevilacqua Sat, 06/19/2010 - 19:34
Configure the destination-pattern for outgoing VoIp more correctly and you will have it working no problem. And CUCM also must be configure for overlap receiving.
daniel.needleman Mon, 06/21/2010 - 02:10
Sorry for my ignorance (I have done this kind of thing before) but what do you mean by...
"Configure the destination-pattern for outgoing VoIp more correctly "
...in what way have I not configured correctly?
You also say that the CUCM must be configured for overlap receiving; why is that?
padutelindus Mon, 06/21/2010 - 06:21
I've just finished a migration of  a site in Italy, he some comments:
1. Italy has an open numbering plan.
2. Calls from international & mobile are send enblock
3. Calls from landlines are send in overlap (DID range prefix + 1,2,3,4,... digits in overlap)
4. To call international numbers 0.00!
5. To call national numbers 0.0!
6. To call mobile numbers 0.3!
7 About the CLIP => Must be in Plan:Unknown, Type:Unknown, only then Telecom Italia will send the complete number
8 Calling Party Number:
     - From National: you need to add 00, calls are taged as Type: National
     - From Mobile: you need to add 0, calls are taged as Type: Mobile
     - From International: you need to add 000, call are taged as Type: International
Here the consfuration I used:
rule 1 // /000/ type international international
rule 2 // /00/ type national national
rule 3 // /0/ type unknown unknown
rule 1 /^746289\(...\)$/ /2649\1/          // DID to 7 digit Internal DN
rule 2 /.+/ /2649001/                         // All other calls to Reception (Calls to main number, Unassigned DID)
voice translation-rule 900
rule 1 /^2649\(...\)$/ /0746289\1/
voice translation-profile PSTN_IN
translate calling 100
translate called 101
voice translation-profile PSTN_OUT
translate calling 900
no ip address
encapsulation hdlc
isdn overlap-receiving T302 6000
trunk-group TG_PSTN_Primary
no cdp enable
dial-peer voice 100 pots
description === incoming call from PSTN = default peer ===
translation-profile incoming PSTN_IN
incoming called-number .T
fax rate disable
direct-inward-dial
dial-peer voice 900 pots
trunkgroup TG_PSTN_Primary
description === outgoing calls to PSTN with digit strip ===
translation-profile outgoing PSTN_OUT
preference 1
progress_ind progress enable 8
progress_ind connect enable 8
I use a 7 digit internal Dialplan, with is build of a 3 digit site code + last 4 digits of DID number.
One last thing, the main number is most of the time just the company prefix, or prefix + digit 0 or 1. so the main number is in most cases shorter then the rest of the DID number.
Hope this helps
Patrice
Paolo Bevilacqua Mon, 06/21/2010 - 19:16
All correct but please note no access digit of '0" is needed. Users will like that because is "like calling from home".
