Migrating CUCM 4.1(3) to CUCM 7.1 (3b) using DMA
Jun 18th, 2010
I have a problem to migrate CUCM 4.1 (3) to CUCM 7.1 (3b) using a DMA version 7.1.3.
When I run DMA, I have the error message in attachment.
Do you think that’s problem of version? it’s correct to migrate directly CUCM 4.1(3) to 7.1(3) or I must to use a version intermediate?
Just for your information, I uninstall the integration with AD before running the DMA, it can provide a problem?
Thanks a lot,
Best Regards,
Omar
Aaron Harrison Fri, 06/18/2010 - 03:42
Your output says you have a succesful output with warnings. This means your DMA file will import, but some things may be missing or broken.
Click the 'Warnings Log' button, and search the logs for 'warning'. If you aren't sure what the warnings mean or how to address them, post it back here.
Aaron
Please rate helpful posts...
omar_youn Fri, 06/18/2010 - 04:05
Hi Aaron,
Thanks too much for your quick answer;
Please, I send you the file Warning in attachement, if you can help me.
I want to know if I run the installation of CUCM 7.1 using this DMA Export file, what conseques would be generated in my New system?
Thanks again,
Best Regards,
Omar
Aaron Harrison Fri, 06/18/2010 - 05:15
I see an LDAP error, presumably due to you having removed LDAP.
Also see errors like this:
Table: CallingSearchSpace                  2010-06-17 19:15:16
   Row: 24 SQL error: -746(35133)
   Error executing "update CallingSearchSpace set Name='SOPHAL_Internat_IPMA_CSS_M_E' where pkid='d2c50042-0008-4804-bac8-29deb4fc1fa5'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -746. sqlerrm(35133)
      pkid                       d2c50042-0008-4804-bac8-29deb4fc1fa5  NOT MODIFIABLE
      Name                       SOPHAL_Internat_IPMA_CSS_M_E
      Description                CDG Manager accès à  l'international
      DialPlanWizardGenID
      Clause                     Generated_IPMA_Managers:logue:Interne:Interdirecteur:VMPilotNumberPT:VMPilotNumber2  NOT MODIFIABLE
      resetToggle                false
      tkReset                    2
      tkPartitionUsage           99  NOT MODIFIABLE
I suspect these are cuased by the 'description' field having special characters in it. Later, other elements also fail:
   Row: 74 SQL error: -746(35133)
   Error executing "update CallingSearchSpaceMember set fkRoutePartition='6223602d-61df-4aad-a497-a451e0afb8bd' where pkid='4ff5ea2f-b2b5-4463-b7ba-2366a688829e'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -746. sqlerrm(35133)
      pkid                       4ff5ea2f-b2b5-4463-b7ba-2366a688829e  NOT MODIFIABLE
      fkCallingSearchSpace       d2c50042-0008-4804-bac8-29deb4fc1fa5  NOT MODIFIABLE
      fkRoutePartition           6223602d-61df-4aad-a497-a451e0afb8bd
      SortOrder                  4
I believe this is because the earlier CSS was not imported to Informix, so the PKID (d2c50042-0008-4804-bac8-29deb4fc1fa5) is not a valid reference.
What I would do is change the single CSS above to have a simple description, and then re-run DMA. If there is no error logged for this on this attempt, I would then correct the description fields on the other CSSs.
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Roland Marti Fri, 06/18/2010 - 06:47
You have used special character.
Remove all äöü ' ^and so on and rerun the DMA.
Chers Roland
omar_youn Fri, 06/18/2010 - 08:48
Hi All,
thanks too much for your help and answer.
I change the Description of CSSs with the simple description, and the no error message about CSS display. But I have always the 2 others messages error:
06/18/2010  16:46:52
Warning: LDAP Operation Failed
ErrorCode = 32
ErrorMessage = No such object
ErrorName = LDAP_NO_SUCH_OBJECT
ErrorText = The server cannot find an object specified in the request
LDAP_HOST    = ccmpublisher
LDAP_PORT    = 8404
LDAP_DN                    = cn=Directory Manager, o=cisco.com
LDAP_PWD                 = *****
Condition: LDAP Search failed
Solution: Please note the LDAP error
I want to inform you that I remove the integration with AD before running the DMA, it’s not recommended to do this action?
Row: 356 SQL error: -746(35288)
   Error executing "update DeviceNumPlanMap set fkDevice='c29fa4f3-9d79-4c26-997d-991c939c1ff4' where pkid='5eaf2ac1-dae7-42d3-ae0a-2d7dbe2cda9c'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -746. sqlerrm(35288)
      pkid                       5eaf2ac1-dae7-42d3-ae0a-2d7dbe2cda9c         NOT MODIFIABLE
      fkDevice                            c29fa4f3-9d79-4c26-997d-991c939c1ff4
      NumPlanIndex                  1
      Label                    FILALI JAOUHARI Abdeslam BLOCKED
      fkNumPlan                        2dd6c08e-1f09-450d-8b0e-295fc38a53ce
      Display                              FILALI JAOUHARI Abdeslam
      tkRingSetting                    4
      CtiID                      356      NOT MODIFIABLE
      E164Mask
      DialPlanWizardGenID
      tkMWLPolicy                     0
      tkRingSetting_Consecutive           0
      MaxNumCalls                    4
      BusyTrigger                      4
      CallInfoDisplayMask          9
      LabelASCII                        FILALI JAOUHARI Abdeslam BLOCK
      DisplayASCII                     FILALI JAOUHARI Abdeslam
      tkRingSetting_ActivePickupAlert
      tkRingSetting_IdlePickupAlert
      SpeedDial
      fkRecordingProfile
      fkCallingSearchSpace_Monitoring
      tkStatus_AudibleMWI        2
      LogMissedCalls                true
there is the second problem, do you have any idea to resolve this problem, please?
In attachement the warning message for more detail.
Thanks a lot,
Best regards,
Omar
Roland Marti Mon, 06/21/2010 - 01:27
Hi Omar
Do not use more than 30 Char in
*      Label                     FILALI JAOUHARI Abdeslam BLOCKED*
*      Display                               FILALI JAOUHARI Abdeslam*
*      LabelASCII                         FILALI JAOUHARI Abdeslam BLOCK*
*      DisplayASCII                      FILALI JAOUHARI Abdeslam*
It should work after them.
       Roland Marti
omar_youn Mon, 07/05/2010 - 07:48
Hi Roland,
Thanks for your answer,
I correct the error message bellow (I use less than 30 charc);
But, when I run DMA, I have always 2 kind of  warnings messages :
First Message:
Row: 76 SQL error: -746(25040)
   Error executing "update NumPlan set fkRoutePartition=NULL where pkid='6e4e4d45-b233-424e-ba5c-065421c445ee'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -746. sqlerrm(25040)
      pkid                       6e4e4d45-b233-424e-ba5c-065421c445ee  NOT MODIFIABLE
      fkRoutePartition
      DNOrPattern                7
      tkPatternUsage             4  NOT MODIFIABLE
      CFBDestination
      CFNADestination
      fkRouteFilter
      tkNetworkLocation          0
      fkDigitDiscardInstruction
      PrefixDigitsOut
      BlockEnable                false
      tkMixer
      CalledPartyTransformationMask
      fkCallingSearchSpace_SharedLineAppear  61779b5b-6941-4527-88ce-5baf31640078
      fkDialPlan
      fkCallingSearchSpace_Translation
      CallingPartyTransformationMask
      PatternUrgency             false
      tkStatus_useFullyQualCallingPartyNum  2
      fkCallingSearchSpace_CFB
      fkCallingSearchSpace_CFNA
      DialPlanWizardGenID
      UserHoldMOHAudioSourceID
      NetworkHoldMOHAudioSourceID
      CallForwardExpansionMask
      tkAutoAnswer               0
      PersonalRoutingEnabled     false
      DeviceFailureDN
      fkCallingSearchSpace_DeviceFailure
      CallingPartyPrefixDigits
      fkCallingSearchSpace_MWI
      fkVoiceMessagingProfile
      CFBVoiceMailEnabled        false
      CFNAVoiceMailEnabled       false
      CFDFVoiceMailEnabled       false
      fkAARNeighborhood
      withTag
      withValueClause
      Description
      CFNADuration
      tkPatternPrecedence        5
      CFAPTVoiceMailEnabled      false
      CFAPTDestination
      tkReleaseCauseValue        0
      fkCallingSearchSpace_CFAPT
      tkPresentationBit_ConnectedLine  0
      tkPresentationBit_CallingName  0
      tkPresentationBit_ConnectedName  0
      tkPresentationBit_CallingLine  0
      SupportOverlapSending      false
      CFAPTDuration
      isCallable                 true
      fkCallManager
      AlertingName
      AuthorizationCodeRequired  false
      AuthorizationLevelRequired  0
      CFBIntDestination
      CFBIntVoiceMailEnabled     false
      CFNAIntDestination
      CFNAIntVoiceMailEnabled    false
      ClientCodeRequired         false
      CSSForCFA
      fkCallingSearchSpace_CFBInt
      fkCallingSearchSpace_PFF
      fkCallingSearchSpace_PFFInt
      PFF_CFB                    false
      PFF_CFNA                   false
      PFFDestination
      PFFIntDestination
      PFFIntVoiceMailEnabled     false
      PFFVoiceMailEnabled        false
      fkCallingSearchSpace_Reroute    NOT MODIFIABLE
      fkMatrix_Presence          ad243d17-98b4-4118-8feb-5ff2e1b781ac
      fkCallingSearchSpace_CFNAInt
      IsMessageWaitingOn         false
      OutsideDialtone            false
      DeviceOverride             false
      AllowCTIControlFlag        true
      AlertingNameASCII
      resetToggle                false
      tkReset                    2
      AARDestinationMask
      AARKeepCallHistory         true
      AARVoiceMailEnabled        false
      CFHRDN
      CFHRIntDN
      CFHRIntVMEnabled           false
      CFHRVMEnabled              false
      CFURDestination
      CFURIntDestination
      CFURIntVoiceMailEnabled    false
      CFURVoiceMailEnabled       false
      fkCallingSearchSpace_CFHR
      fkCallingSearchSpace_CFHRInt
      fkCallingSearchSpace_CFUR
      fkCallingSearchSpace_CFURInt
      fkCallingSearchSpace_revert
      HRDuration
      HRInterval
      ikNumPlan_ParkCode
      RevertDestination
      CFHRDuration
      tkDeviceSecurityMode_MinimumAllowed
      tkCFACSSActivationPolicy   0
      fkResourcePriorityNamespace
      tkNumberingPlan_Called     0
      tkPriOfNumber_Called       0
      tkPriOfNumber_Calling      0
      tkNumberingPlan_Calling    0
      fkDevice_IntercomDefault
      DNOrPatternIPv6
      tkStatus_PartyEntranceTone  2
      ParkMonForwardNoRetrieveDN
      ParkMonForwardNoRetrieveIntDN
      ParkMonForwardNoRetrieveIntVMEnabled  false
      ParkMonForwardNoRetrieveVMEnabled  false
      fkCallingSearchSpace_PkMonFwdNoRet
      fkCallingSearchSpace_PkMonFwdNoRetInt
      ParkMonReversionTimer
Second message:
Row: 1046 SQL error: -746(35259)
   Error executing "update PhoneButton set ButtonNum=22 where pkid='7926e6fd-7c8f-4966-8fa8-5c37c669f738'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -746. sqlerrm(35259)
      pkid                       7926e6fd-7c8f-4966-8fa8-5c37c669f738  NOT MODIFIABLE
      fkPhoneTemplate            b7371212-0ddc-4fa2-9abd-37bd8848ad7c  NOT MODIFIABLE
      ButtonNum                  22
      tkFeature                  255
      Label                      None
      ParamN1                    14
      ParamN2
      ParamT1
      ParamT2
      isFixedFeature             false  NOT MODIFIABLE
      resetToggle                false
      tkReset                    2
if you have any ideas about what could the cause of those messages i'll be really grateful.
Best regards
Omar
