outside NAT
Jun 18th, 2010
Hi all,
How do i configure outside NAT such that my external public ip is map to one of my  dmz private ip.
What i want is when any address on the internet connects to my public ip on a certain port it will translate to my dmz ip which my server is using.
I am using asdm to configure my cisco asa 5510 firewall. I did a NAT for my source public ip to be translated to my dmz ip. I then set an accesslist to allow any incoming ip on a specific port to access the public ip i configure for outside NAT. But it didnt work. Pls advise. Thks in advance.
Jennifer Halim Fri, 06/18/2010 - 05:31
With CLI:
static (DMZ,outside) netmask
With ASDM:
Configuration --> Firewall --> NAT Rules --> Add Static NAT rule -->
Original interface: DMZ
Source: dmz-private-ip
Translated interface: outside
Use IP Address: external-public-ip
Then click: OK, and apply.
Access-list applied on the outside interface should allow traffic from "any" towards the external public ip on certain tcp/udp ports.
Hope that helps.
donnie Sat, 06/19/2010 - 22:13
Hi Halijenn,
Thk you for your prompt response. I know of the steps required for NAT stated in your reply. What i am looking for is when any internet ip access my public ip eg 203.x.x.10 and 203.x.x.11 it will automatically translate to my 1 private ip eg We use to have 2 private ip(, translate to the 2 public ip stated above, but we have merge the 2 servers into 1.
We would like to continue to use the 2 public ip so that it is a transparent transition for our external customers. Thks in advance.
gatlin007 Sun, 06/20/2010 - 08:40
I'm not sure if this approach is supported but I've used something like this in the past when migrating external addresses; proceed at your own risk.
access-list tango permit ip any host any
static (dmz,outside) 203.x.x.10
static (dmz,outside) 203.x.x.11 access-list tango
Jennifer Halim Sun, 06/20/2010 - 18:42
Unfortunately you can't translate 2 public ip addresses to just 1 private ip address as it is not supported.
