ACE module only inserting X-Forwarder Header on first packet
Answered Question
Jun 18th, 2010
As above, I have a strange problem where if I use my proxy server to access an LB VIP then it is inserting the X-forwarding header for Each GET request.
However if I make the request direct from my PC (not via Proxy) it inserts the header on the first packet but no subsequent packets unless I restart the browser.
Any ideas????
Correct Answer by Sean Merrow about 6 years 4 months ago
Hi Scott,
In the ACE documentation, check out the section on Configuring the ACE to Modify Headers on Every HTTP Request or Response.
I hope this helps,
Overall Rating: 5 (1 ratings)
scott-goodwin Fri, 06/18/2010 - 06:22
Thanks Sean, that has cured our initial problem in the test enviroment, just rolling it out to live network so fingers crossed
