WLC 4400: User Account must not expire
Jun 18th, 2010
  • Silver, 250 points or more
Hi all.
Currently we have wireless guest user accounts added onto the wlc and they expire in 30days. No problem with this.
However, the wireless infrastructure is to be used by internal employees with local account db held on wlc. Can this be setup such that their account will never expire?
thanks a lot
Ajaz
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 06/18/2010 - 05:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ajaz,
Most possible my friend
Local Net Users
You can change a guest user account with a non-zero lifetime to another lifetime value at any
time while the account is active. However, to make a guest user account permanent using the
controller GUI, you must delete the account and create it again. If desired, you can use the config
netuser lifetime user_name 0 CLI command to make a guest user account permanent without
deleting and recreating it.
From the Lifetime drop-down boxes, choose the amount of time (in days, hours, minutes, and seconds)
that this guest user account is to remain active. A value of zero (0) for all four fields creates a permanent
account.
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52users.pdf
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
