pls find the attachement , i have problem regarding switch redundany if we coonect two uplink from one switch than there is loop occured so by what configuration we can avoid the loop , or give any example to check it.
One the L2 switches do you have single vlans or multiple vlans?
Since the L3 switches are in stack you might want to go for etherchannel between the L2 floor switch and the L3 stack switches.
regds
