ASA 5520 with CSC-SSM-20
Answered Question
Jun 18th, 2010
Hi!
I have purchased a Cisco ASA 5520 having a CSM-SSM-20 module.
I have got the Product Activation Key (PAK) that must be used to register the device on Cisco.com.
I understand that when I register the product, a license will be made available which must be used as Activation Code in the CSCSetup Wizard.
My query is:
Will the CSC SSM subscription status be active as soon as I register the device on Cisco.com using the PAK
Or
Will it be active only after I have registered the device, got the license and completed the CSC Setup Wizard?
Alvin
Correct Answer by Jennifer Halim about 6 years 9 months ago
The CSC SSM subscription status will be activated as soon as you registered the device using PAK from cisco.com licensing page.
Hope that confirms it.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Fri, 06/18/2010 - 07:33
  • Cisco Employee,
