7942 - can I setup 2 headsets?
Jun 18th, 2010
Hi all ... I'm managing an IPT implementation, and we've run across an issue with our small call center.
Today, they have phones that can have two headsets connected. They use this for training and demos. It allows someone to sit at the desk of the agent and listen in without any impact to the call. The hosted call center product they use allows supervisors to monitor calls, however even if they let a user use this, they would be sitting at a different desk which defeats some of the training purpose.
So my question is does anyone know of a solution to allow two headsets be used used at the same time on the 7942? Thanks in advance!
Overall Rating: 5 (1 ratings)
Aaron Harrison Fri, 06/18/2010 - 06:51
  • Community Spotlight Award,
    Member's Choice, May 2015
You have one headset socket; however I have seen people use this type of thing for training:
http://www.plantronics.com/north_america/en_US/products/office/office-headset-accessories/y-adapter-trainer
Maybe speak your headset supplied to see if they have something similar.
Aaron
Please rate helpful posts...
Rob Huffman Fri, 06/18/2010 - 06:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Peter,
Aaron is right on the money here! (+5 my friend)
We use these with many models (including the 7942) and they
work perfectly with Plantronics H-series headsets.
Cheers!
Rob
CHRIS CHARLEBOIS Fri, 06/18/2010 - 07:00
  • Silver, 250 points or more
I had to setup something similiar, but I needed two handsets.  I just used an rj-11 splitter.  The port was a little wider than the handset jack, but the connection was solid.  I would assume that headsets are similar.
Related Content
