Best way to limit bandwidth ? ( on 3750 )
Jun 18th, 2010
I would have your help on this question :
Users are connected on switch Catalyst 3750.
Connection from Cisco go on VoIP phone, and computers are connected on VoIP phone for lan/internet acces.
I want to limit bandwidth for user on lan/internet acces, but not on Voice. Voice and data are on different vlan.
Here is exemple on one port :
interface GigabitEthernet1/0/16
description D8
switchport access vlan 30
switchport mode access
switchport voice vlan 90
switchport port-security maximum 2
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
spanning-tree bpduguard enable
Anyone could tell me ( with exemple please ) a good way to do it ?
I have read some doc about it, talking about policy map, acl, max bandwidth limit, etc...
Sebastien
devils_advocate Fri, 06/20/2014 - 02:18
  • Gold, 750 points or more
  • Community Spotlight Award,
    Small Business, November 2015
It depends on where you want to apply the 'limiting'.
Do you want to do it for a whole subnet, an individual host or a specific host port?
A policy map, combined with an ACL is likely the way to go but it depends on the question I asked above.
Parvesh Paliwal Fri, 06/20/2014 - 04:24
you can easily prioritize the traffic for the time. Try changing the DSCP values so that it gets better precedence values for certain kind of traffic.
Parvesh
Neno Spasov Fri, 06/27/2014 - 19:13
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 AAA, Identity and NAC Security
There really isn't a "best" way as that would depend on what your end goal is. For instance, do you want the excess traffic to be buffered or dropped. Take a look at this link that I found very helpful when configuring QoS policies on the 3750 platform:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-...
Hope this helps!
Thank you for rating helpful posts!
