Supervisor 32/PISA Missing AutoQos command
Jun 18th, 2010
We recently purchased a new 6509-E with the sup32-Pisa in it.
the problem is i have went through all the IOS's i can find and cannot seam to find the Auto Qos commands. They are not on the interface nor at the config lines. I have found several areticles that speicify that it does exist in 12.2 (18) ZYA2. Yet when i apply that version the command is still not there that i can find.  Does anyone know what version of IOS for the Sup32-Pisa has it or if it is removed when is it coming back?
Viral Bhutta Tue, 06/22/2010 - 18:23
  • Cisco Employee,
As far as I know auto Qos is not supported on SUP32 Pisa
Check out the release notes under Unsupported Features and Commands.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/ios/12.2ZY/release/notes/ol_13011.html#wp44862
Probably what you can do is copy the commands from other switches running auto QoS to SUP32 Pisa since Auto QoS is a set of pre-defined commands.
