PXE boot through router
Answered Question
Jun 18th, 2010
We have two LAN in my enterprise.One LAN is for server and other is for users.Cisco Router act as a DHCP server for the user LAN.Now we are planning for PXE boot for user LAN.My PXE boot server is located in the server LAN.What are the changes needs to be done at the router to make this work.
Correct Answer by Giuseppe Larosa about 7 years 1 week ago
Hello Uthayaman,
on client vlan facing router interface you need the command
ip helper-address pxe-server-address
this command converts unroutable packets with broadcast destination to routable packets with unicast destination = pxe-server-address
one field in the packet is updated with the router's IP address of client facing interface so that DHCP server can pick up an IP address from correct address pool
to be noted LAN switch ports should be configured with spanning-tree portfast otherwise PXE boot can fail for the STP standard timers (up to 30 seconds before making the port operational)
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 06/18/2010 - 10:15
  • Hall of Fame,
    Founding Member
Hello Uthayaman,
Hope to help
Giuseppe
uthayaman Fri, 06/25/2010 - 15:10
Thx...
I have done this.Now my clients are not getiing IP from the DHCP server.We have a MPLS VPN(Provided by a service provider) between the client and server.Whether this will block DHCP boot request packet from client to server.
I can arble to see the gaddress getting changed in the clients gateway(Router A) and forwaded to DHCP server.But this is not reaching the router B.
Client<------>RouterA------MPLS-----------RouterB<-------->DHCP server
Do i need to take it up with my service provider.Because i never faced any such issue with MPLS link till now.
Giuseppe Larosa Sun, 06/27/2010 - 12:02
  • Hall of Fame,
    Founding Member
Hello Uthayaman,
thanks for your kind remarks
but can you ping from RA's lan ip address to RB's lan ip address ?
in any case I agree that you need to involve the SP
Hope to help
Giuseppe
Related Content
