CSM-S to ACE migration
Jun 18th, 2010
If the private key and certificate pairs are imported from CSM-S to ACE for SSL termination, will they work on ACE?
litrenta Tue, 06/22/2010 - 06:44
yes as long as they are valid you can use them on the ace.
For ace you would use the server cert and key in the ssl-proxy, and use the imtermediate and/or root cert in a chaingroup and then configure the chaingroup under the ssl proxy .
