multicast iptv stream from provider
Jun 18th, 2010
We have an provider for iptv, he sends us a multicast stream on a certain source e.g. 239.232.1.1
The source for this stream is an ip-address on his network e.g. 104.103.102.1
We don't get an ip-address from him on this subnet.
We have no route to him.
All we have is the connection coming in on one gigethernet port of our Cat6509  e.g. int Gi4/20
There is no PIM between us and the iptv-provider
Our network is Layer3 connected like this
        int gi4/20 link to iptv provider
corerouter1     int gi2/1   ip address  172.29.1.1/30   ------------------------------ corerouter2   int gi2/1 ip address 172.29.1.2/30
                     int gi2/2   ip address   172.29.1.181/30                                                 int gi2/2 ip address 172.29.1.185/30
                                 |                              cat4507re clientrouter                                        |
                                 ----------    int gi1/1                                             int gi1/2 --------------------
                                              ip add 172.29.1.182/30                          ip add 172.29.1.186/30
                                             also  router for vlan 2117  ip address 172.29.17.254/24
clients for the iptv are on the 'client router' in vlan 2117
Actually there are a lot of different client routers with clients on different vlans, but the fundamental setup is the same.
Multicast routing is enabled everywhere , sparse-dense on all interfaces
corerouter1 and corerouter2 are configured to be candidate RP's
corerouter2 is the actual RP
Problem: how do I get the clients on clientrouter on vlan2117 to receive the multicast stream coming from the provider.
If I configure int gi4/20 on corerouter2 to be an access switchport in a vlan , the clients in that vlan receive the stream,
but nobody outside that vlan receives the stream.
I've been looking at igmp-proxy but I don't know if that is the right solution for my problem.
Any help will be much appreciated.
Kind regards.
D. Vanoverschelde
rababosama Thu, 12/09/2010 - 05:57
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Trebuchet MS","sans-serif"; mso-ascii-font-family:"Trebuchet MS"; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:"Trebuchet MS"; mso-hansi-theme-font:minor-latin;}
Hi D. Vanoverschelde
I think the solutions of this problem to create sparse-dense mode into the giga Ethernet and interface vlan on both corerouter2 and cat4507
You can solve this problem by creating ip pim sparse-dense mode into the interface giga and interface vlan
Or you can create port channel on both routers like the following
At corerouter2:
1-    Create port channel
# interface Port-channel2
description "To cat4507"
ip address 172.29.1.185 255.255.255.252
ip pim sparse-dense-mode
2-    Configure   int gi2/2
     description "To cat4507 client router"
     no ip address
     logging event link-status
     channel-group 2 mode on
## If you don’t need to create port channel on both routers, so you can add ip pim command into the interface giga2/2 on corerouter2 and the interface giga1/2 on client router
At cat4507re clientrouter :
1-    Create port channel:
description "To corerouter2"
ip address 172.29.1.186 255.255.255.252
2-    Configure   int gi1/2:
     no ip address
3-    Create any interface vlan :
interface Vlan 2117
ip address 172.19.17.254 255.255.255.0
ip pim sparse-denese-mode
ip route-cache flow
ip igmp version 3
Hope to help!! And update me
Rabab Osama
Remember to rate the helpful post
