How to change the CSM default "admin" password?
Jun 18th, 2010
Hello, I have CSM software installed in W2K3, using CiscoWorks authentication, I have created few local user and assign appropriate role the account able to login, I want to change the default "admin" password, that is no admin account define under CiscoWorks role, then I found the admin password change field under CSM client - Security Administration Menu - Remote Token, I change it and save close the client then open it again to login the new pass not work, old pass working, I did the same step to change the password again under remote token but samething happen.
Any master can give me advice.
Related Content
Trending Topics - Security & Network
