06-18-2010 08:53 PM - edited 03-19-2019 01:06 AM
Dear All,
I need setup a UC cluster 7.x and receive the following PAK from Cisco.
UNITYCN7-HA-24, UNITY CONNECTION HIGH AVAILABILITY PLATFORM OVERLAY and
Will the Publisher of the UC cluster needs to be installed both PAK license? or Will the add on member of cluster need the PAK UNITYCN7-HA? I need to clarify this before apply the license file from Cisco, thanks! Michael. |
Solved! Go to Solution.
06-18-2010 09:16 PM
Yep, that thread is 100%. You need to generate 2 licenses. The first is based on the MAC address of the Pub and should be a full license (all fields in it populated). The second is based on the MAC of the Sub and should be an HA license. You may need to work with licensing@cisco.com to make sure this license is created properly. The Sub will inherit ports, users, etc from the Publisher license. The HA license for the Sub only contains the ports you purchased for HA, voice rec sessions, etc (port-based info).
Hailey
Please rate helpful posts!
06-18-2010 09:04 PM
Hi Michael,
Here is a recent thread that Hailey and I were working on that addresses this question
https://supportforums.cisco.com/message/3108164#3108164
Cheers!
Rob
06-18-2010 09:16 PM
Hailey
