LMS 3.2 Multiserver active/backup
Answered Question
Jun 19th, 2010
I currently have one LMS 3.2 server and i want to deploy another server with it making an active passive configuration so that when one server is down, i can manage through another server. I need document for this type of deployment. Also that if its recommened to use active passive ?
Correct Answer by Joe Clarke about 7 years 4 days ago
Yes, a hot standby configuration is definitely one way to go with LMS.  This scenario is documented at http://www.cisco.com/en/US/partner/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/white_paper_c07-533663.html#wp9000401 .  There are also other HA solutions you can use which involve Veritas or VMWare.  See http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/hasetup.html and http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/vmware.html for more details on those configurations.
Note: with hot standby you will need two licenses for LMS.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sat, 06/19/2010 - 18:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
