Routing for GRE tunnel Destination
Jun 19th, 2010
We have two links from ISP and both are terminated on Same Backbone /Core Router
One on Giga Ethernet Gi0/0 -- and another on Gi0/1
One is primary Link and other is used as backup
We have created GRE for both the Links to destination with address as 10.10.2.100
GRE Tunnel Configurations are something like
Tunnel 1
Ip address 192.168.0.1 255.255.255.252
tunnel source Gi0/0
Tunnel destination 10.10.2 100
keepalive 5 2
ip tcp-adjust mss 1436
Tunnel 2
Ip address 192.168.0.9 255.255.255.252
tunnel  source Gi0/1
keepalive 5 2
Since tunnel destination is same for both Links but Tunnel 1 is made for Primary link terminated on Gi0/0 and Tunnel2 made for backup link terminated on Gi0/1
we have put a specific route like
ip route 10.10.2.100 255.255.255.255 192.168.0.2
and whenever primary link goes down we have to change the specific route
ip route 10.10.2.100 255.255.255.255 192.168.0.10
since this requires manual intervention , is there some way we can keep the second route as floating and should come in picture only when primary goes down because incase primary link goes down , router still is able to reach next hop 192.168.0.2
Both links provided by ISP come from two MUX ports placed in our premises
Andrew Yourtchenko Sat, 06/19/2010 - 07:04
  • Cisco Employee,
You can automatically issue the commands onto CLI by using the EEM, take a look at http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht_eem.html
That said, the next hop values that you have specified are probably not that you use, because this configuration would not work due to recursive routing:
Router(config)#ip route 10.10.2.100 255.255.255.255 192.168.0.2
Router(config)#^Z
Router#
00:07:44: %SYS-5-CONFIG_I: Configured from console by console
00:07:53: %TUN-5-RECURDOWN: Tunnel0 temporarily disabled due to recursive routing
00:07:54: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
Marwan ALshawi Sat, 06/19/2010 - 07:38
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
snice you have keepalive configured on the tunnel interface, then any issue with the links connectivity on the first lin kwill take the tunnel interface to down state
in this case you can use the following routing config:
ip route 10.10.2.100 255.255.255.255 192.168.0.10  5
when the tunnel 1 gose down the second route with higher AD will be used, once the tunnel comes back to up state the original static route will be used as it has lower AD
good luck
if helpful Rate
sohail_sarwar Sat, 06/19/2010 - 10:32
Hi Marwanshawi
AD will not come in picture in this case because Gi0/0 is directly connected to MUX Port Say X and Gi0/1 is directly connected to MUX Port Say Y
What i mean is that the route 10.10.2.100 will not flush when first link goes down because the exit interface for this route is 192.168.0.2 , which is always reachable from Gi0/0 ( 192.168.0.1) irrespective of whether MPLS link beyond MUX Port is UP or Down
Ofcourse tunnel 1 will go down but Tunnel 2 will not come up because the route for its destination still remains via same MUX port ( ip route 10.10.2 100 255.255.255.255 192.168.0.2
Try to understand the destination of Both GRE Tunnels is same 10.10.2.100
Richard Burts Sat, 06/19/2010 - 20:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Perhaps I do not understand your environment or your post very well. You indicate that you have configured this static route:
But this should not work. It specifies that you should get to the destination of the tunnel by gong through the tunnel.  And that results in recursive routing. For the tunnel to work you need to specify a route to the tunnel destination that does not involve the tunnel.
Perhaps if you provide more information about the environment, especially the configuration of Gi0/0 and Gi0/1 we might understand better and be able to provide better answers to your issue.
Rick
