Not enough nvram memory in AP
Jun 19th, 2010
I encounter one issue in AP. Not sure why the directory of nvram does not have any file and cannot write memory to the AP.
AP#wr
%No memory available
%No memory availablestartup-config file open failed (Not enough space)
AP#dir nvram:
Directory of nvram:/
%Error calling getdents for nvram:/ (Unknown error 89)
Leo Laohoo Sat, 06/19/2010 - 17:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Errr ... It should be "dir flash:".
kian_hong2000 Sun, 06/20/2010 - 17:57
There is configuration in the startup. However, once i reload the AP the configuration will be lost.
Not sure why cannot save the configuration in the AP
Leo Laohoo Sun, 06/20/2010 - 18:24
  • Hall of Fame,
    2017 LAN, Wireless
What is the output to the command "dir flash:"?
abersven Mon, 06/21/2010 - 13:50
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
The routers NVRAM might be faulty and if so you need an RMA and that is a issue that must be solved through TAC.
You can try the following first. Just press enter to confirm:
ROUTER#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
ROUTER#write memory
Building configuration...
[OK]
ROUTER#
Above you see how the router should respond.
/André
