what's the difference of XFP-10G-MM-SR,SFP-10G-SR and XENPAK-10GB-SR? Can they connect each other?
Answered Question
Jun 19th, 2010
We are connecting a ASA 10G port with SFP-10G-SR to SCE 10G port with XFP-10G-MM-SR and C7609 10G port with XENPAK-10GB-SR, can they connect each other? or it is manadatory use the same SFP module for the connection?
Correct Answer by Jerry Ye about 7 years 5 days ago
The should be fine. According from the data sheet
SFP-10G-SR is 850nm MMF
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
XFP-10G-MM-SR is 850nm MMF
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd802a61b9.html
XENPAK-10GB-SR is 850nm MMF
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps5455_Products_Data_Sheet.html
As long as the wave lenght and fiber type matched, they should be able to communicate.
HTH,
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Sat, 06/19/2010 - 12:19
  • Cisco Employee,
HTH,
jerry
