Got a 1841 router and don't have a clue where to get started.
Jun 19th, 2010
None of the documentation tells me how to get going. have sdm installed on a pc but how to do i get it to recognize the pc.  this router will be in between the cisco router that nuvox installed and our network to provide our own ip addresses.
Richard Burts Sat, 06/19/2010 - 20:39
Tom
You do not indicate whether this 1841 is a new router (purchased directly from Cisco or from an official reseller) or is a "previously deployed" router. If it is an new router then it should be set up to provide DHCP on the FastEthernet0/0 interface. Configure your PC for DHCP and connect to FastEthernet0/0. Your PC should be assigned an IP address and SDM should be ready to go.
If it is a previously deployed router then it may not perform DHCP. In this case your choices are either to try to guess what addressing is configured on the router interfaces and configure your PC to match. Or you can connect your PC to the console port of the router (using an appropriate Cisco console cable) and use the command line to make some changes in the router config. If you want to use SDM then you would need to configure an IP address on one of the LAN interfaces and configure your PC with a corresponding address.
Rick
