CUCM backups
Jun 19th, 2010
Hi, I have a callmanager cluster and parts of backup complete with "error".  I've attached a screenshot.  Not sure why, but the following backup components always fail.  Anyone seen this?
Overall Rating: 5 (1 ratings)
David Hailey Sun, 06/20/2010 - 18:50
Interestingly, all of the failures take place at the same point within each file (4096 bytes).  What is the name of the SFTP server application you are using to backup files to?
mcdonovan Mon, 06/21/2010 - 07:32
Hi David.  The backup server is a Unix box and we use SSH to send the backups.
Robert Thomas Mon, 06/21/2010 - 12:03
Is this server a PUB or a SUB, do you have the TFTP service activated on this node?
What about a restart to the DRF master and local services, a lot of temporary issues with DRF take care this way. The restart should not impact network operation as this two services take care exclusively for the backups.
mcdonovan Mon, 06/21/2010 - 13:01
Hi Robert, the server is the Pub (only server in cluster) and running TFTP.  I'll restart DRF services, re-run backups and let you know the results.  Thanks!
mcdonovan Thu, 06/24/2010 - 10:46
Hi Robert,
I restarted the DRF services reran backups and issue is still happening.  Below is the error at the bottom of one of the failed backup logs.  On a related note I backup other clusters to the same SFTP server with no issues:
tar: -: Wrote only 4096 of 10240 bytes
tar: Error is not recoverable: exiting now
2010/06/25 00:37: sudo tar -cvpPf - /var/log/active/cm/report/rtmtreporter 2>> /common/drf/backup.log
2010/06/25 00:37: Backup failed.
yiosepvaldes Mon, 09/06/2010 - 21:12
hello everyone,
i have the same problem with that version of cucm.
i have attach the TXT file with the errors on two services after begin the backup process and reports files on cucm.
Could you find the solution for this problem?
thanks for any help
yiosepvaldes Wed, 09/08/2010 - 20:07
hi matthew,
thanks for your respond, that document of cisco explain all, i changed the sftp client for other of name "FreeFTPd".
thanks for help me.
