modifying saved report on webview
Jun 20th, 2010
Dears,
i have space problem on AW , C  and D drives are full, i need temp solution by moving some folders to another server or location .
the biggest folder on C is 'WebViewExportData' on where the saved/exported reports of webview are stored.
this folde is 15 GB , i moved its contents to another location but i can't now run any saved reports, how can i make the webview pointing to the new loacation to enable run the already saved/exported reports ?
david.macias Sun, 06/20/2010 - 09:47
  • Blue, 1500 points or more
I've never tried what you said, but I would only assume that you would have to re-run setup.  I'm going to take a wild guess here and say that you've never deleted the saved reports from supervisors who left and now you have a lot of accounts with reports which are never used.
david
