Frame-relay subinterface help
Answered Question
Jun 20th, 2010
I have a 2901 router that will be used to connect to an ISP and then our inside network will be connected through one of the Gig-ports on the 2901. I cannot figure out how to create a sub-interface on the 2901, it will not allow me to do it like I have done on other type of routers. The only way I can get it to configure anything at all is by:
interface Serial0/1/0:0
ip address x.x.x.x y.y.y.y
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
enacapsulation frame-relay IETF
frame-relay interface-dlci 500
frame-relay lmi-type ansi
crypto map SDM_CMAP_1
usually I would do it by:
no ip address
encapsulation frame-relay IETF
ip route-cache flow
interface Serial0/1/0.500 point-to-point
frame-relay interface-dlci 500 IETF
Thanks for your help.
Correct Answer by Richard Burts about 7 years 1 month ago
It looks like the card in your router requires that you configure the T1 controller using the channel-group 0 command to create the serial interface. This produces a serial interface name like interface Serial0/1/0:0. Your comments seem to think that this creates a subinterface. But this is the name of the physical interface (the : 0 is a by-product of the channel group definition). Have you tried configuring interface Serial0/1/0:0.500 point-to-point?
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Sun, 06/20/2010 - 12:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rick
j.mccartney Sun, 06/20/2010 - 16:31
The problem is that I cannot create a sub-interface at all from this point that's what my issue is. I have other 1841's that I have in the past that have had no problems creating a sub-interface. So my question is will the physical interface work with everything config'd on it (encap, lmi)?
Richard Burts Sun, 06/20/2010 - 17:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
You do not indicate whether you have actually attempted my suggestion to configure  interface Serial0/1/0:0.500 point-to-point. Can you clarify whether you have attempted this or not?
Assuming that your Frame Relay connection has only a single DLCI then I believe that your configuration with all parameters on the physical interface should work.
Note that the configuration with all parameters on the physical interface produces a multipoint interface while the subinterface that you suggest would be point to point. Some protocols (like OSPF) react differently to multipoint or point to point. Since you have not provided any information about your router environment, we are not able to offer advice about whether the difference between multipoint or point to point will make much difference.
Rick
j.mccartney Sun, 06/20/2010 - 17:55
Hi again Rick,
Sorry I didn't clarify my last response. Yes,  I did try to create the subinterface as pt-pt to no avail, there were no commands even there to allow me to do a  "interface Serial0/1/0:0.500 point-to-point. Yes, we only have one DLCI too.
What we are doing is having a T1 installed at a remote site that is connected back to our HQ for a site-site VPN for data/phones. But the kicker is this is the first time we have done it with a 2901 in this topology. We have other sites that are utilizing MPLS VPN, some using Time Warner cable modem. Usually we have a T1 utilizing a site-site VPN (remote site ASA to our corp ASA) where we have a router connecting to an ASA and then to a switch for the local LAN.
I will try it again tomorrow when I get into my office and reply. The 2901 integrates the router/firewall in one device, so I'm trying some new things here. I do appreciate your help and suggestions.
John
j.mccartney Mon, 06/21/2010 - 06:00
Hello Rick,
I was able to get it finally working with a sub-interface. I'm not sure what I was doing wrong before, but thanks for your help.
John
Richard Burts Mon, 06/21/2010 - 08:51
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
John
I am glad that you got it working. Thanks for letting us know.
Rick
