06-20-2010 10:49 AM - edited 03-04-2019 08:50 AM
We have a PFC3B and all the linecards have DFC3Bs and we cannot hold the full internet routing table
So I'm going to suggest we need to get the PFC3BXL upgrade. My question is with regards to the DFCs, are we going to have to upgrade them to DFC3BXL or can we upgrade the memory using MEM-XCEF720-1GB.
Many Thanks in advance
Dom
Solved! Go to Solution.
06-21-2010 07:37 AM
And can you also confirm that just fitting the extra memory to a module with a DFC3B installed won't do anything?
Yes, I have confirmation that this will not work at all. The reason is because the TCAM size on the DFC3BXL is different from the DFC3B.
For your other question about the part number, I think the best thing for you to do is contact your Cisco system engineer and account manager. I don't want to give you wrong information since I don't deal with part number daily.
jerry
06-20-2010 07:54 PM
You will have to replace the DFC3B broad with a new DFC6BXL board, along with upgrade memory (default 256MB) on the line cards. You should contact your Cisco sales team for the detail part numbers.
HTH,
jerry
06-21-2010 01:37 AM
Hi Jerry - Thanks for your reply.
According to this URL, the DFC3BXL comes with the 1Gb sim for the line card - http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_bulletin0900aecd8017a5db.html
If I order a WS-F6700-DFC3BXL, will I get the daughter card and a 1Gb SIMM to fit onto the linecard?
Cheers, Dom
06-21-2010 07:37 AM
jerry
06-21-2010 08:14 AM
Thanks Jerry
