Intergrating Cisco Unity with Cisco Unified Call Manager Express
Jun 20th, 2010
I'm trying to configure my CUCME to work with my Unity 7 using VMware. i've created the VoIP dial-peer and configured the voicemail configuration under my ephone-dn 1 templete but when I go to hit the message button it will not dial to the unity server it gives me a busy signal. Any ideas why I can't connect to Unity?
Overall Rating: 5 (1 ratings)
Aaron Harrison Sun, 06/20/2010 - 23:39
  • Community Spotlight Award,
    Member's Choice, May 2015
What dial peer have you configured?
What communication method is Unity configured for? SCCP? SIP?
Aaron
khayes1984 Mon, 06/21/2010 - 04:46
We are using SCCP for right now. We will eventually move over to SIP here soon.
dial-peer voice 3 voip
description CUVM1
huntstop
preference 1
max-conn 4
destination-pattern 107
session protocol sipv2
session target ipv4:10.0.1.14
dtmf-relay rtp-nte
codec g711ulaw
Aaron Harrison Mon, 06/21/2010 - 04:52
You'll need to read the manual I think - there is a specific guide for each type of integration to each type of system. SCCP with CME is here:
https://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/cucme_sccp/guide/cuintcucmeskinny030.html
You say you are using SCCP, but you have configured a SIP dial-peer; that obviously won't work. There is no need for any dial-peers with an SCCP integration.
Aaron
Please rate helpful posts...
khayes1984 Mon, 06/21/2010 - 05:02
I've tried that manual before and I don't think it worked correctly.  I'll remove that dial-peer for SIP, and try that link you gave me again, however when I tried to setup the mwi on-off it would not allow me to because it was saying something about mwi is not allowed on dn-1.
Aaron Harrison Mon, 06/21/2010 - 05:05
Stick with the manual; when you get to something that doesn't work post back.
Aaron
This email communication does not create or vary any contractual relationship between Logicalis and you. Internet communications are not secure and accordingly Logicalis does not accept any legal liability for the contents of this message. The contents of this email are confidential to the intended recipient at the email address to which it has been addressed. It may not be disclosed to or used by anyone other than this addressee, nor may it be copied in any way. If received in error, please contact Logicalis on the above switchboard number quoting the name of the sender and the addressee and then delete it from your system. Please note that neither Logicalis nor the sender accepts any responsibility for viruses and it is your responsibility to scan the email and attachments (if any).
Logicalis UK Ltd, Registered in England and Wales No: 3732397, Registered Office: 110 Buckingham Avenue, Slough. Berkshire, SL1 4PF
