Telepresence with CUBE/SBC
Jun 20th, 2010
  • Silver, 250 points or more
We may soon require CUBE/SBC functionality for our Telepresence system.  Can we use a normal router running a CUBE IOS, or do we need to purchase a purpose built SBC?  The traffic is not expected to exceed 100Mb/s or around 3 - 5 Telepresence sesisons at any one time.
In either case, are there configuration examples for the CUBE and/or SBC for use with Telepresence?
Thanks.
Overall Rating: 5 (1 ratings)
gogasca Tue, 06/29/2010 - 18:05
  • Green, 3000 points or more
Yes, you can use regular CUBE in router
Now it requires a separate license, check which IOS image is required for TP support, you may confirm this with your Cisco AM,
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/index.html
http://www.cisco.com/en/US/partner/docs/telepresence/cts_admin/1_6/compatibility/cts_compatibility_1_6.html
Check presentation attached for configuration example
Nick Halbert-Li... Tue, 07/13/2010 - 16:29
My account doesn't have access to view those files.....
I currently have a 2821 running:
c2800nm-adventerprisek9_ivs-mz.124-22.YB4.bin
Is this enough, or are there additional licenses etc that need to be applied?
We currently have it working audio only - no video.  It appears to negotiate the audio Codec OK, but not the video.
As a test, we are sending to the CUBE and back to the same CUCM.  The CUCM trunk and route pattern are configured as Offnet - nothing else out of the ordinary for the trunk/route pattern.  The trunk is in the same region as the CTS units.
In the config/logs below, the following details are relevant:
CUBE IP: 192.168.238.243
CUCM IP: 192.168.247.225
CTS endpoint 1: 192.168.247.243
CTS Endpoint 2: 192.168.231.243
CUBE Config:
interface FastEthernet0/0
ip route-cache same-interface
voice service voip
! address-hiding
allow-connections sip to sip
codec profile 1 aacld
fmtp "fmtp:96 profile-level-id=16;streamtype=5;config=11B0;mode=AAC-hbr;sizeLength=13;indexLength=3;indexDeltaLength=3;constantDuration=500"
codec profile 2 h264
fmtp "fmtp:112 profile-level-id=DEFGHI;sprop-parameter-sets=Z00AKAoWVAPAEPI=,aGFLjyA=;packetization-mode=1"
dial-peer voice 1 voip
description Inbound Call Leg
incoming called-number 41103
codec aacld profile 1
video codec h264 profile 2
rtp payload-type cisco-codec-fax-ind 120
rtp payload-type cisco-codec-aacld 96
rtp payload-type cisco-codec-video-h264 112
session protocol sipv2
codec transparent
dial-peer voice 11 voip
description Outbound Call Leg
destination-pattern 41101$
session target ipv4:192.168.247.225                                       <-------- CUCM address
codec transparent
CUBE Debug during the call:
Jul 13 23:16:22.568: //51/7C3BE6F8808E/SIP/Error/sipSPIAddCiscoGcid: Fatal Error in parsing CCB/Msg
RCO2CBE-01#
SIP: Attribute mid, level 1 instance 1 not found.
SIP: Attribute mid, level 2 instance 1 not found.
Jul 13 23:16:30.469: //-1/xxxxxxxxxxxx/SIP/Error/convert_codec_bytes_to_ptime: Unexpected VoIPCodec Type :aacld
Jul 13 23:16:30.477: //52/7C3BE6F8808E/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
Jul 13 23:16:30.477: //-1/xxxxxxxxxxxx/SIP/Error/convert_codec_bytes_to_ptime: Unexpected VoIPCodec Type :aacld
Jul 13 23:16:30.481: //-1/xxxxxxxxxxxx/SIP/Error/sipSPICheckAndClearSrcSRTPSdp: CCB SDP source pointer NULL
Jul 13 23:16:30.485: //-1/xxxxxxxxxxxx/SIP/Error/sipsdp_add_media_c_line: media_src_address is NULL; c-line is not added
Jul 13 23:16:30.489: //51/7C3BE6F8808E/SIP/Error/sipSPIAddCiscoGcid: Fatal Error in parsing CCB/Msg
SIP: (51) Group (a= group line) attribute, level 65535 instance 1 not found.
Jul 13 23:16:30.521: //51/7C3BE6F8808E/SIP/Error/sipSPIProcessAckMedia: Could not modify QoS params for midcall INVITE
Jul 13 23:16:30.525: //51/7C3BE6F8808E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x496BB940
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : YES
Calling Number           : 41103
Called Number            : 41101
Source IP Address (
RCO2CBE-01#Sig  ): 192.168.238.243
Destn SIP Req Addr:Port  : 192.168.247.225:5060
Destn SIP Resp Addr:Port : 192.168.247.225:37751
Destination Name         : 192.168.247.225
Jul 13 23:16:30.525: //51/7C3BE6F8808E/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream             : 1
Negotiated Codec         : g722-64
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 9 (tx), 9 (rx)
Negotiated Dtmf-relay    : 9
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.238.243
Source IP Port    (Media): 16966
Destn  IP Address (Media): 192.168.231.243
Destn  IP Port    (Media): 30626
Orig Destn IP Address:Port (Media): [ - ]:0
Media Stream             : 2
Negotiated Codec         :
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 0
Source IP Port    (Media): 18384
Destn  IP Port    (Media): 27100
Source IP Address (Sig  ): 192.168.238.243
Media Stream             : 1
Media Stream             : 2
Negotiated Codec         :
Jul 13 23:16:30.525: //0/000000000000/SIP/Error/sipSPIPutSCBInClientTable: Failed to add SCB to Client table
Jul 13 23:16:30.529: //52/7C3BE6F8808E/SIP/Error/sipSPIUpdateSrcSdpFixedPart:  owner_sessionid is already their OR src_sdp
                        is corrupted
Jul 13 23:16:30.537: //52/7C3BE6F8808E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x496C0C04
TCP Sockets Used         : NO
Called Number
RCO2CBE-01#         : 41101
Destn SIP Resp Addr:Port : 192.168.247.225:5060
Jul 13 23:16:30.537: //52/7C3BE6F8808E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17752
Destn  IP Address (Media): 192.168.247.243
Destn  IP Port    (Media): 26200
Media Stream             : 2
Negotiated Codec         :
Source IP Port    (Media): 18500
Destn  IP Port    (Media): 30978
Jul 13 23:16:31.077: //52/7C3BE6F8808E/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
Jul 13 23:16:31.077: //52/7C3BE6F8808E/SIP/Error/sipSPIDoVideoNegotiation: Destination port is zero in media line 2
Jul 13 23:16:31.237: //51/7C3BE6F8808E/SIP/Error/sipSPIDoVideoNegotiation: Destination port is zero in media line 2
Jul 13 23:16:31.241: //51/7C3BE6F8808E/SIP/Call/sipSPICallInfo:
Jul 13 23:16:31.241: //51/7C3BE6F8808E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Media Stream             : 2
Negotiated Codec         :
Source IP Port    (Media): 0
Destn  IP Port    (Media): 0
SIP: (52) Group (a= group line) attribute, level 65535 instance 1 not found.
RCO2CBE-01#
Jul 13 23:16:35.109: //51/7C3BE6F8808E/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
Jul 13 23:16:35.113: //51/7C3BE6F8808E/SIP/Error/sipSPIDoVideoNegotiation: Destination port is zero in media line 2
Jul 13 23:16:35.133: //52/7C3BE6F8808E/SIP/Error/sipSPIDoVideoNegotiation: Destination port is zero in media line 2
Jul 13 23:16:35.137: //52/7C3BE6F8808E/SIP/Call/sipSPICallInfo:
Calling Number           : 41101
Jul 13 23:16:35.137: //52/7C3BE6F8808E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
RCO2CBE-01#
Media Stream             : 2
Negotiated Codec         :
------CALL END-------
Jul 13 23:27:24.718: //52/7C3BE6F8808E/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Jul 13 23:27:24.718: //52/7C3BE6F8808E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Media Stream             : 2
Negotiated Codec         :
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Jul 13 23:27:24.734: //51/7C3BE6F8808E/SIP/Call/sipSPICallInfo:
Jul 13 23:27:24.734: //51/7C3BE6F8808E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
RCO2CBE-01#
Media Stream             : 2
Negotiated Codec         :
MARTIN STREULE Tue, 07/20/2010 - 06:37
Do you have the following commands configured?
voice service voip
rtp-ssrc multiplex
address-hiding
sip
  midcall-signaling passthru
  session transport tcp
  header-passing error-passthru
  pass-thru content sdp
  rel1xx disable
There was a session at the last CiscoLive! event "BRKUCC-2305 - Interconnecting Voice and Video over IP Networks with Session Border Controllers" which had some info about that (config example) and there is a book "SIP Trunkting" which contains some info.
hth
Martin
Nick Halbert-Li... Tue, 07/20/2010 - 16:03
We put those commands in and it worked immidiately!
Thankyou!
