Back-up interface routing problem
muratg7777
Hi;
I have configured 887 Router. ADSL with 3g(backup) everything is fine but the routing seems not working.
interface ATM0
backup delay 120 60
backup interface Cellular0
no ip address
no atm ilmi-keepalive
dsl bitswap both
ip nat inside source route-map adsl interface Dialer0 overload
ip nat inside source route-map cell interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0 2
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
route-map cell permit 10
match ip address 1
match interface Cellular0
route-map adsl permit 10
match ip address 1
match interface Dialer0
Tha nat is working but the routing seems not working. When I run remove "ip route 0.0.0.0 0.0.0.0 Dialer0" command I can connect internet.
I have tried also track command :
ip route 0.0.0.0 0.0.0.0 Dialer0 track 210
ip route 0.0.0.0 0.0.0.0 Cellular0 track 250
but it did not work. When I disconnect adsl line and run sh route, I see dialer 0 is the default route for 0.0.0.0.  I need to configure backup route for 0.0.0.0 network
12 Replies 12
Ganesh Hariharan
Hi;
interface ATM0
backup delay 120 60
no ip address
dsl bitswap both
match ip address 1
match ip address 1
Can you try with the below config on IP SLA track configuration on automatic failover of the primary link:-
ip sla 1
icmp-echo "destionation ip"
timeout 500
frequency 3
ip sla schedule 1 start-time now life forever
track 1 rtr 1 reachability
now for the routing, we need to change the default route and associate it with the tracker
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 1
Then we need to add our secondary route
ip route 0.0.0.0 0.0.0.0 1.1.1.2 10
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Richard Burts
Murat
The issue here is that your default route specifies the dialer interface but even though you may have lost connectivity through the ATM interface the dialer interface still remains line protocol up and so the default route remains in the routing table and your floating static route never gets used. I see that you have tried using the track command but it seems to not work for you. Perhaps you could post some details of how you attempted to implement it. The post by Ganesh does show a way to implement the track/IP SLA.
Rick
Rick
Thanks for the replies. I did not configure ip sla so that's why  tracking was not working. The other configuration is typical adsl and 3g  config.
So the config will be:
ip sla 1
timeout 500
frequency  3
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0  0.0.0.0 Cellular0 track 10   or metric 10 ???
Murat
I do not see any reason to involve tracking for the floating static. So I believe that it would work with ip route 0.0.0.0  0.0.0.0 Cellular0 2
Rick
Rick
Thanks. I am gonna try it
Hİ;
I finally did a sample config but routing seems problem again.
ip local policy route-map track-primary-if
ip route 0.0.0.0 0.0.0.0 Dialer0 track 234
ip route 0.0.0.0 0.0.0.0 f3 254
ip nat inside source route-map nat2cell interface f3 overload
ip nat inside source route-map nat2dsl interface Dialer0 overload
ip sla 1
icmp-echo 88.247.244.1 source-interface Dialer0
timeout 1000
frequency 2
ip sla schedule 1 life forever start-time now
access-list 191 permit ip 192.168.11.0 0.0.0.255 any
access-list 192 permit icmp any host 88.247.244.1
route-map track-primary-if permit 10
match ip address 192
set interface Dialer0
route-map nat2dsl permit 10
match ip address 191
route-map nat2cell permit 10
match interface f3
This is the sample config I did it on 877 router.
There is default route ip route 0.0.0.0 0.0.0.0 Dialer0 on it when I run no ip route 0.0.0.0 0.0.0.0 Dialer0.  S*   0.0.0.0/0 is directly connected, Dialer0
deletes from routing table and I am not able to connect to internet.
Tracking it seems working:
Router#show ip sla statistics
Round Trip Time (RTT) for       Index 1
        Latest RTT: 11 milliseconds
Latest operation start time: *18:27:27.043 UTC Tue July 20 2010
Latest operation return code: OK
Number of successes: 587
Number of failures: 0
Operation time to live: Forever
Router#sh ip route track-table
ip route 0.0.0.0 0.0.0.0 Dialer0 track 234 state is [undefined]
Atm interface config:
interface ATM0
no ip address
load-interval 30
dsl operating-mode auto
interface ATM0.1 point-to-point
backup interface FastEthernet3
pvc 8/35
  pppoe-client dial-pool-number 1
I found the mistake.
was wrong
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1 state is [up] now
Murat
I am glad that you got it figured out and working. Thank you for posting back to the forum indicating that you have got it working and what you did to get it to work. Seeing solutions to problems like this helps to make the forum more useful.
Rick
Rick
Actually "track 1 rtr 10 reachability" was missing. It's ok now. But I have second problem;
let's say
dsl public ip : 1.1.1.80
isp side gateway : 1.1.1.1
3g: 2.2.2.80
I am tracking the isp side gateway 1.1.1.80. When I unplugged dsl line, backup interface (3g) comes up but routing is flapping between; dsl and 3g and I am getting these logs:
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1 state is [down] now
I can not ping 1.1.1.80 maybe from acl I did not have time to check acl
ip sla 1
icmp-echo 1.1.1.1 source-interface Dialer0
doesn't it mean to track from dialer 0 interface only? so why it is tracking also from cellular0 interface?
If I write deny acl for icmp and bind it to cellular 0 interface, does it work? I am far away from the location now so I couldn't tried.
Secondly, I have tried with another operator's data sim card, and this config did work with it.
Hi Murat,
I am also triynig to configure 3g bakcup line with primary DSL line.  I need some advice about configuraiton.
My situation can be bit different from yours, because DSL line is point to point. And 3G line has DMVPN configurations. Both lines works fine as a primary.
But second step is backup configuration,problem here.
I configure ip sla, track is working. But when I let both line is up, I thing is routing confuse, than I lost connection to the headquerter.
Could you please check my config ? Any thing look wrong...I am lost in config now:(
x.x.x.x head quarter real ip
x.x.x.z track ip
! Last configuration change at 14:04:58 UTC Tue Feb 8 2011
version 15.1
no service pad
service password-encryption
hostname IST_DPC
boot-start-marker
boot system flash c880data-universalk9-mz.151-2.T2a.bin
boot-end-marker
logging buffered 51200 warnings
enable secret *****
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2733612712
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2733612712
revocation-check none
rsakeypair TP-self-signed-2733612712
ip source-route
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
chat-script internet "" "ATDT*99#" TIMEOUT 60 "CONNECT"
username ****  password *****
controller Cellular 0
ip ftp source-interface Vlan1
ip ftp username ozgur
ip ftp password 7 1418080C1916
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key *** address x.x.x.x
crypto ipsec transform-set *** esp-3des esp-md5-hmac
crypto ipsec profile   ****
set transform-set ****
interface Tunnel1
ip address 192.168.168.2 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp map multicast x.x.x.x
ip nhrp map 192.168.168.1 x.x.x.x
ip nhrp network-id 5
ip nhrp nhs 192.168.168.1
ip nhrp registration no-unique
tunnel source Dialer1
tunnel mode gre multipoint
tunnel key 5
tunnel protection ipsec profile ******
interface ATM0
no ip address
pvc 8/35
  pppoe-client dial-pool-number 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface Cellular0
description "### 3g interface ###"
no ip address
ip virtual-reassembly in
encapsulation ppp
load-interval 60
dialer in-band
dialer pool-member 1
async mode interactive
no fair-queue
interface Vlan1
ip address 172.25.190.1 255.255.255.0
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
backup interface dialer1
ip directed-broadcast
encapsulation ppp
ip tcp adjust-mss 1300
dialer pool 2
ppp authentication chap pap callin
ppp chap hostname *********
ppp chap password  ****
ppp pap sent-username *****   password *******
no cdp enable
interface Dialer1
ip flow ingress
encapsulation ppp
shutdown
dialer pool 1
dialer idle-timeout 0
dialer string internet
dialer persistent
dialer-group 1
ppp authentication chap callin
ppp chap refuse
ppp pap refuse
ppp ipcp dns request
no cdp enable
router eigrp 5
network 172.25.190.0 0.0.0.255
network 192.168.168.0
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Dialer0 2
ip route 0.0.0.0 0.0.0.0 Dialer1 254
ip sla 1
icmp-echo x.x.x.z  source-interface Dialer0
logging esm config
access-list 1 permit any
access-list 120 permit icmp any host x.x.x.z
no cdp run
match ip address 120
control-plane
line con 0
login local
no modem enable
line aux 0
line 3
exec-timeout 0 0
script dialer internet
modem InOut
no exec
transport input all
speed 237000
line vty 0 4
privilege level 15
login local
transport input telnet ssh
end
Hi Kerime;
Here is my working config:
track 1 ip sla 1
ip slow-converge
ip route 0.0.0.0 0.0.0.0 Cellular0 10
ip route 78.189.xx.xx 255.255.255.255 Dialer0
ip sla 1
icmp-echo 78.189.xx.xx source-interface Dialer0
timeout 1000
frequency 2
access-list 1 permit 192.168.35.0 0.0.0.255
access-list 110 permit icmp any host 78.189.xxx.xxx
match ip address 1
match ip address 110
match ip address 1
Hi I arrange right IP to track, everything is fine now.
Thank you all
