MPLS backup using VPN
Jun 21st, 2010
Dear  Forum,
I wonder if someone might be able to assist me with a question I have.
I have a head office which connects to remote offices using MPLS.  This is a managed service and I do not have write access to these routers (cisco 1800) series.  At each of the sites, head office and remote I also have an internet leased line and a Cisco ASA.  This provides me with local access to the internet for eac of the sites and it gives me the opportunity to create VPN between the sites as a back up connection in the event of the MPLS line being unavailable.
However can I create a failover so that no manual intervention is required?  This Cisco ASA is the default gateway for the  hosts at each of the sites so I can use this to make routing decisions
I have attached a simple diagram of my environment
Thank you for reading and thank you for any suggestions
David
milan.kulik Tue, 06/22/2010 - 00:01
  • Red, 2250 points or more
have you asked your MPLS provider for an opinion?
Some providers offer an MPLS connection with a cheap Internet  VPN backup.
If you have more than just two sites connected to the MPLS backbone, it could be a good solution for all your sites.
It's always easier to configure something with the provider cooperating.
BR,
Milan
